Power plans help please??
chinfisc
Hi, I have two laptops, one an Acer running Vista Home 64bit and the 2nd a Toshiba Satellite running Vista Home 32bit. On my Acer 64bit, when I unplug the AC it automatically switches from High Performance to Balanced without me doing anything. I like this, is there any way to do it on my Toshiba as well, it does not automatically do do so...THANKS!
GOTO CONTROL PANEL---- POWER OPTIOND- THEN ADVANCED SETTING .then there should be an option to change power plan when plugged in or running on batterie
not done this for a while on laptop but im sure thats how its done
    Acer Apire m3201
    AMD Phenom 9150e Quad core processer 1.8ghz
    4gig corsair 800 mhz
    ATI Radeon 4870 512mbs gdr5
    32"
    320gb
    ocz extreme 600 watt
    4.0mbs
