Weird - Very weird annoying problem
GeorGeZ
Gaming Addict
Hello,
I have just installed ms office professional recently. I usually open this program for a game. When i open it it gives me this -- Imageshack - 85374956
It happened with this program. I dont think it does with the other ones..
This has not happened until i installed ms office 2007. im really pissed now because i have had quite alot of problems with it. I might just uninstall it and never install it again because its interfeiring with other programs. If anyone can help cool if not ill just uninstall it.
    Dell
    Intel(R) Core(TM)2 Duo CPU @2.66GHz Inspiron 530
    NVIDIA GeForce 8600 GT
    Relatek High Def.
    DELL SE198WFP(Digital)
    2x 250GB Sata HardDrives
    Inspiron 530 Case
    Heatsink Fan
    Razer DeathAdder 3500 DPI
    Dell Standard Keyboard
    18mbps
Nothing happens if you wait for it to "finish configuring"? May I suggest trying to run it as administrator? Even if you're running an administrator account, you may want to try and give the program administrator privileges; right-click on the program you're running and select Run as Administrator.
    HP dv5-1120ej Notebook PC
    Intel Dual 2.16GHz
    NVidia GeForce 9200M GS, 256MB
    320GB internal, 320GB external, 1TB external to come (big download library XD)
    Fast enough
    Firefox, Foobar, and AutoHotkey! Go open source!
Tried both... still the same..:( look at the image.. if i leave it it does it over and over again but if i click about 7 times cancel the program would open.
    Dell
    Relatek High Def.
    Inspiron 530 Case
    Heatsink Fan
    18mbps
It's a bad install, something got messy in the registry. You have several options:
>> Use a registry cleaner (such as CCleaner) to clean up any mess that may cause this. (Some people on this forum might advise against using programs that tamper with the registry - either way, be careful what you erase from your temporary files and registry)
and/or
>> Uninstall and reinstall Office (requires install disc). I suggest using a thorough uninstaller like Revo to uninstall and make sure no traces are left behind to mess up the new installation.
or
>> Use OpenOffice instead of MS Office.
(All free software solutions, btw)
    Intel Dual 2.16GHz
    Fast enough
Hello,
George
Why would you use microsoft office for a game. It has nothing to do with games and will slow down your gaming if it is open. It looks like it is associated with a shortcut when it shouldn't be
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
zigzag im not using it for a game... if i double click it thats what it shows me..
VaguelyRapt i might just uninstall it forever. because i also had a problem when i installed it there was no skin. no skin at all it was just like 3 small buttons where to close and minimize and maximize separated all together with a big space between them and all was white :sarc:
Im waiting for a reply from zigzag - so ..no im not opening it with ms office.
Sorry for being such a pain ...
    Dell
    Relatek High Def.
    Inspiron 530 Case
    Heatsink Fan
    18mbps
Okay i uninstalled it and it worked! I might have a go later and try again. I also disabled uac:D
So for me its gonna be - Problem Solved
PS: Thanx all for help
    Dell
    Relatek High Def.
    Inspiron 530 Case
    Heatsink Fan
    18mbps
