Installing x32bit to a x64 bit vista help?
Almondz
Well , My laptop that I've bought came with a pre-installation of Windows Vista x32 home premium. I'm trying to install the x64 bit version because it's a 64bit processor. How do I do this ? I have the x32 bit product key that should work on the x64 bit version?
Some manufacturers give a free 64 bits installation dvd as an upgrade. Call your manufacturer and ask. If not, you will have to buy another vista.
    HP 6730s
    Intel Core 2 Duo T5670 @ 1.80 ghz 4 mb L2 Cache
    2 GB Ram DDR2
    Intel 4500MHD 128 MB own ram, 796 shared
    HD Audio Output
    1280x800 max on the laptop (1920x1080 on Full Hd Screen :) )
    150 Gb Toshiba 7200 rpm
    7 Mega download, 1 mega upload
