So I got a new laptop, and Asus x3v8b-x2 with Vista Home Premium 64bit SP1 on it. It was working beautifully for almost a month, then a couple days ago I started it up and noticed that the it was taking forever to load and that my sidebar wouldn't show up. I then noticed that I couldn't click on anything, and then vista told me that explorer.exe was not responding. So I restarted it, but it just froze again, and when I tried to restart it wouldn't. So I turned it off manually, and when I turned it back on it was fine. I ran Avira antivirus free version, spybot, and ad-aware. Nothing. The next day upon starting it, the same thing went down. So I manually turned it off and left it off for the rest of the day. Today, I tried to turn it back on, and upon logging into my account (the only one), it lagged, and explorer didn't start up at all. I just got a black screen with a white mouse (I could still move my mouse) but the start button on my keyboard didn't do anything, and I couldn't get into task manager either. So I manually turned it off, started it in safe mode w/ networking, the thing lagged, and I got a black screen with the words safe mode in the corners and a white cursor. Awesome. Turned it off, turned it back on in regular mode, now it works. What? So yeah, I'm having problems, and it seems like many others are having very similar problems, but no one has any solutions, so why should my situation be any different? Well I guess I can try. I'm pretty certain that I did not install / update anything a couple days ago that would have triggered this, I have no spyware/adware that I can find. I don't have the vista cd's, just the manufacturer's recovery discs. It was working just fine before. I've also been using it for the past hour or more and it hasn't frozen yet, the problem happens upon startup. Anything else I can think of? No... oh yeah, specs and stuff.
Core 2 Duo T6400
4gb ram
250gb hard drive
512mb nVidia geforce 9300m gs
vista home premium 64bit sp1
All my drivers are updated, I always do the windows updates and what not... umm.. you probably want hijackthis?
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 2:16:51 PM, on 8/3/2009
Platform: Windows Vista SP1 (WinNT 6.00.1905)
MSIE: Internet Explorer v7.00 (7.00.6001.18294)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\ASUS\SmartLogon\sensorsrv.exe
C:\Program Files (x86)\ASUS\ASUS Live Update\ALU.exe
C:\Program Files (x86)\Windows Sidebar\sidebar.exe
C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe
C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files (x86)\uTorrent\uTorrent.exe
C:\Program Files (x86)\Lavasoft\Ad-Aware\AAWTray.exe
C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktop.exe
C:\Program Files (x86)\CyberLink\Power2Go\CLMLSvc.exe
C:\Program Files (x86)\ASUS\ATKOSD2\ATKOSD2.exe
C:\Program Files (x86)\ASUS\ATK Media\DMedia.exe
C:\Program Files\ASUS\ASUS Data Security Manager\ADSMTray.exe
C:\Program Files (x86)\Java\jre6\bin\jusched.exe
C:\Program Files (x86)\Avira\AntiVir Desktop\avgnt.exe
C:\Program Files (x86)\Windows Live\Contacts\wlcomm.exe
C:\Windows\SysWOW64\taskmgr.exe
C:\Program Files (x86)\Mozilla Firefox\firefox.exe
C:\Program Files (x86)\TuneUp Utilities 2008\Integrator.exe
C:\Program Files (x86)\Trend Micro\HijackThis\HijackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = Bing
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = Bing
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~2\MICROS~1\Office12\GRA8E1~1.DLL
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [CLMLServer] "C:\Program Files (x86)\CyberLink\Power2Go\CLMLSvc.exe"
O4 - HKLM\..\Run: [P2Go_Menu] "C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"
O4 - HKLM\..\Run: [HControlUser] C:\Program Files (x86)\ASUS\ATK Hotkey\HControlUser.exe
O4 - HKLM\..\Run: [ATKOSD2] C:\Program Files (x86)\ASUS\ATKOSD2\ATKOSD2.exe
O4 - HKLM\..\Run: [ATKMEDIA] C:\Program Files (x86)\ASUS\ATK Media\DMedia.exe
O4 - HKLM\..\Run: [ADSMTray] C:\Program Files\ASUS\ASUS Data Security Manager\ADSMTray.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [AdobeCS4ServiceManager] "C:\Program Files (x86)\Common Files\Adobe\CS4ServiceManager\CS4ServiceManager.exe" -launchedbylogin
O4 - HKLM\..\Run: [avgnt] "C:\Program Files (x86)\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [Sidebar] C:\Program Files (x86)\Windows Sidebar\sidebar.exe
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKCU\..\Run: [uTorrent] "C:\Program Files (x86)\uTorrent\uTorrent.exe"
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun (User 'Default user')
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~1\Office12\EXCEL.EXE/3000
O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~1\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~1\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~1\Office12\REFIEBAR.DLL
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O13 - Gopher Prefix:
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\PROGRA~2\MICROS~1\Office12\GR99D3~1.DLL
O20 - AppInit_DLLs: C:\PROGRA~2\Google\GOOGLE~1\GOEC62~1.DLL
O23 - Service: ADSM Service (ADSMService) - ASUSTek Computer Inc. - C:\Program Files\ASUS\ASUS Data Security Manager\ADSMSrv.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: Avira AntiVir Scheduler (AntiVirSchedulerService) - Avira GmbH - C:\Program Files (x86)\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files (x86)\Avira\AntiVir Desktop\avguard.exe
O23 - Service: ASLDR Service (ASLDRService) - Unknown owner - C:\Program Files (x86)\ASUS\ATK Hotkey\ASLDRSrv.exe
O23 - Service: ATKGFNEX Service (ATKGFNEXSrv) - Unknown owner - C:\Program Files\ATKGFNEX\GFNEXSrv.exe
O23 - Service: @dfsrres.dll,-101 (DFSR) - Unknown owner - C:\Windows\system32\DFSR.exe (file missing)
O23 - Service: FLEXnet Licensing Service - Acresso Software Inc. - C:\Program Files (x86)\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: FLEXnet Licensing Service 64 - Acresso Software Inc. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe
O23 - Service: Google Desktop Manager 5.7.802.22438 (GoogleDesktopManager-022208-143751) - Google - C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files (x86)\Lavasoft\Ad-Aware\AAWService.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: Remote Procedure Call (RPC) Net (rpcnet) - Absolute Software Corp. - C:\Windows\SysWOW64\rpcnet.exe
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: SBSD Security Center Service (SBSDWSCService) - Safer Networking Ltd. - C:\Program Files (x86)\Spybot - Search & Destroy\SDWinSec.exe
O23 - Service: @%SystemRoot%\system32\SLsvc.exe,-101 (slsvc) - Unknown owner - C:\Windows\system32\SLsvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: Syntek AVStream USB2.0 WebCam Service (StkSSrv) - Unknown owner - C:\Windows\System32\StkCSrv.exe (file missing)
O23 - Service: @%SystemRoot%\System32\TuneUpDefragService.exe,-1 (TuneUp.Defrag) - Unknown owner - C:\Windows\System32\TuneUpDefragService.exe (file missing)
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
I hope that's right. If there are any other things you want me to post just say so, and explain how to do it please! I'm not really sure what I'm doing with all this stuff! So, like, you probably want eventviewer, if someone could explain to me what to post or how to get a log thing that would be great. I'm thinking about installing SP2 and seeing if that will work, but I'm scared to, because last time I installed a new service pack in our old xp desktop the entire computer died and we had to have it fixed.. so.. any suggestions or comments or anything would be really greatly appreciated!! Thank you!!
Core 2 Duo T6400
4gb ram
250gb hard drive
Boot mode: Normal
Running processes:
