Hello. I'm really, really stuck with deleting a file on Vista, and I saw these boards, they appear to be very good, so I decided to ask here.
So basically, I've got this old version of Java that I want to replace. The files are located at C:\program files\java. I managed to delete all the files, except these two. I renamed them to 1.exe and 2.exe so that it would be easier for me to atempt deleting them, but I know one of them is called jucheck.exe. Both are in the bin folder (c:\program files\java\bin). I am logged on to the administrator account of Vista (the actual admin, not an admin account). Whenever I try to delete them, I get an 'Access denied' error message. I've tried everything I can think of--I changed their WIC level to low, no program is using them, I tried forcibly deleting them in command prompt with the -f and /q atributes, changing their ownership, editing their sicurity settings, renaming them, deleting their file contents, I don't know what else is left to do. If anybody can enlighten me on how to delete the file, I'd apreciate it.
Thanks in advance,
~Hussain
Thanks in advance,
~Hussain
- Dell XPS420
- Intel Cor2 Quad
- 3GB
- 700GB
