Remove mouse click animated water drop effect
claybutler
    i7 920
    Asus P6T Deluxe V2
    12 GB Corsair Dominator 1600
    Evga GEForce GTX280
    4 Caviar Black 1TB ( Two arrays - Raid 1) 2 150 GB velociraptors (One array - Raid 1)
It looks like a Control Key Mouse Pointer option available in Home Premium.
Ultimate may have that as an option for Mouse-Down.
Go to Mouse Options thru Control Panel.
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
I've gone through all the setting for cursors and pointers and mouse effects. That one you mentioned is for finding the cursor by using the Control key and has an entirely different effect. I get this effect every time I click on anything. Have no idea where it's coming from and I've been searching for hours to find an answer. Does anyone else get the water drop effect when they click. Oh I forgot to mention I use a Wacom tablet. The effect is only when using the pen. The Wacom has no setting for effects.
Can't believe I forgot to mention that one. Doh!
    i7 920
    Asus P6T Deluxe V2
    Evga GEForce GTX280
Found it. It's a weird Vista thing. Under Control Panel/Pen and Input Devices, there's a tab for Pointer Options. It has the water drop effect by default. Just unchecked it. How dumb, like I need a visual clue to tell me if I'm tapping my pen.
Thanks for replying though.
    i7 920
    Asus P6T Deluxe V2
    Evga GEForce GTX280
