Folder Picture/Customization Problem
YoungLero
I like to put pictures on all my folders for videos and music. I just got an external hard drive because I need more space, so I moved the videos onto the new drive. The pictures did not stay on the folders when moved them to the new drive, and no matter how many times I try, I can't get them to show up on the folders. I tried saving a picture I want to use as "folder.jpg" within one of the folders, but that doesn't work.
This really annoying, so if anyone knows how to fix it I'd greatly appreciate it.
Thanks
Thanks
i think you woudn't mind if i ask u :D. What is the exact problem, Are u want to use the folder.jpg as icon for the folder? or you want your system to show the image while looking at the folder?
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
I want the folder to have the selected picture as its cover I guess. I don't want it as an icon. I want it to look like a folder with a picture in it. I right click the folder, click customize, click choose file, but the picture doesn't show up. It works fine on my C drive, but not at all on my external drive. I tried a fix I found online that said to put the desired picture in the folder and name the picture "folder.jpg," but that didn't work.
while clicking customize>choose file are you getting window like this?
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
