Explorer problem on start and context menus and long starting programs
Neophile
Hello,
Explorer is no longer working properly in a few ways. Programs often take a long time to start and display “(Not responding)” on the their top window frames. Right click menu sometimes takes a long time to appear while explorer freezes. The explorer window itself is sometimes quite long to change the display when I change folder (this is far from often, but happens).
The first window to appear when we click on the Start Menu, the one with the large icons, is usually OK, but sometimes it does the same as the “All Programs” second window;
Here, the folders do not open and on Task Manager I can watch explorer taking up all the CPU available resources immediately after I pass to “All Programs”;
However, if I click “Back” (explorer stops abnormally using all CPU resources);
Then I click “All Programs” again and the previously clicked folder is now already open, but explorer is again up with CPU resources, so if now I click on a subfolder or on another folder, it all repeats again.
At this moment I don’t have backups to install.
I have read the tutorial about Start Menu, and also another post at http://www.vistax64.com/vista-general/74151-right-click-item-start-menu-explorer-crash.html. I followed this post and disabled all explorer extensions, but it didn’t make any difference, so my problem must not be the same as the one on that post. I wonder what it is. I am convinced it must be something external to explorer that affects its performance, but I can’t discover what it is, so that I’d be very thankful for any kind help.
    Home assembled
    AMD Athlon 64 II X3 440
    M4A785TD-V EVO
    Kingston kit 4GB DDR3 1333MHz (KVR1333D3N9K2/4)
    EAX 300-SE X/TD/128M
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Seagate Barracuda ST3120022A ATA Western Digital Caviar Black WD1002FAEX SATAIII Western Digital WD800BB ATA
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Not sure what it is, try cleaning ur registry + defragging your computer.
Google Auslogics and get the free reg cleaner + defragmenter.
    HP dv6000 CTO Entertainment Lappy :D
    Intel Core 2 Duo T8300 @ 2.4GHz (2 CPUS), ~2.4 GHz
    4094 MB Ram
    NVIDIA GeForce 8400M GS, 2031 MB Memory
    Realtek Hi-Def Sound Card
    Generic PnP Monitor
    1200x800
    HP Laptop :D
    Fans
    Microsoft Pro Mouse :D
    Laptop
    DL: 20.51 Mb/s, Up-Load :5.27 Mb/s Ping: 10 ms
Thank you DarkDavil. I defrag the discs every three days automatically using Task Scheduler. I also clean the registry frequently with Uniblue's RegistryBooster. To be sure, I just did it again as you said, but nothing changed.
I noticed that on the right (black) side of the start menu there is no problem, even when when I point to the admin tools that I have there. It behaves as I described for the left side first window (the large icons) that appears when we start clicking on the start menu.
What can it be, please?
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Hi ltwally. No, I didn't reboot after disabling the extensions. So I was very glad when I read your post because I thought it was that. I went quickly to try it, but the computer took over 10 min to reboot; I had downloaded some updates and it was long. Unfortunately, after rebooting nothing changed. It is disgusting that I can't fix it. What else can it be, please?
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
I could not solve this issue. Isn't there someone to kindly help, please? this is so annoying and I'm not able to get rid of this after all this time.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Just as an experiment create a new User Account and
see if the problem persists there. If not you can transfer your personal files to
the new account and ignore or delete the old one.
Ardneh
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
Hello Ardneh, thanks for your tip. I created a new user account witht Computer Management. Before transferring my files and deleted the old one I tried this new account. Unfortunately, the problem remained exactly as on the old account. I'm very sorry it didn't work. What else can I try, please?
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Neophile:
I don't see from the posts whether you've tried doing a System Restore from Safe Mode.
Ardneh
    Compaq/SR5130NX
Yes, I did it at the beginning, but with so result. Sorry I didn't mention before. Thanks again for the help.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Download shell menu view and disable non microsoft extensions with that tool and check
One more thing, is your computer a part of your organization or school network?
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
Thank you so much for the good will on trying to help, Delphin.
I have already tried your recommendation. Maybe it is not very clear, but I mentioned on the last paragraph of my initial post on this thread. It refers to another thread on this forum with that recommendation(http://www.vistax64.com/vista-general/74151-right-click-item-start-menu-explorer-crash.html). I found strange that the guy on that thread soved his problem, but I didn't. Except for Avast, which I re-enabled, I still have all explorer non Microsoft extensions disabled.
My computer is a home stand alone. Thank you for any welcome help.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Neophile:
This may not apply but if you have Dual-Core or Dual processor computer
try this:
Open Task Manager, Processes tab, on the explorer.exe entry that is hogging resources - Right click - click Set Affinities... and if both are checked then uncheck one of them.
This is not a solution but it might make the computer easier to work with as you continue to troubleshoot.
Ardneh
    Compaq/SR5130NX
Thanks Ardneh. I have an AMD Athlon 64 3500+ processor, as per the specs on my profile, so the right clicking you mention doesn't not show the Set Affinities option. And yes, as soon as i click (or wait on to change) on All Programs on the Start Menu the explorer jumps up taking CPU resources to a varying (not stabilized) 50% to 90%. All help welcomed.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Ardneh, I followed the Microsoft instruction with System Configuration. No result. Only a few were not Microsoft's. Then I disabled everything, both services and startup, Microsoft or not. Nothing changed even when all disabled and on safe mode. I couldn't disable Avast completely because it always re-enabled itself. Many thanks, we have to try something else.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Neophile:
This might work for you:
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
You may need to borrow somebody's retail Vista-SP2-Integrated
install disc to make this work, if your situation doesn't meet the
prerequisites, described at the link.
Just remember to use your Product Key if re-activation is needed.
Ardneh
    Compaq/SR5130NX
Neophile,
I prepared a new hkcr hive for u. Before editing the hive, pls take a complete registry backup and create a restore point. so that we can restore if anything goes wrong.
download the View attachment 14642 and extract the hkcr.reg save it your c drive.
Before following this step, clean boot your system, and close all the application, terminate all the processes except microsoft and windows critical process.
open regedit by typing regedit in run. expand hkey_classes_root and delete all the subkeys inside hkey_classes_root manually, except .reg this key will give the association to merge the hkcr.reg
While deleting some keys, they will not allow you to delete.. it will say access denied. Leave those subkeys and delete all the other keys.
Finally you will only have .reg and some other keys inside hkcr.
Now open your c drive and double click on the hkcr.reg now the key will be merged. Restart your computer and check your explorer.
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
I had these two answers from Ardneh and Delphin. I couldn’t do Ardeneh’s right away even if it was chronologically the first because I should slipstream SP2 and this would take a long time. So I went to try Delphin’s instruction. However this proved to be even longer because I had to clear all the registry keys one by one. The reg file from the HKCR that I saved is over 45MB. Now, clearing the keys one by one would be very long but possible, but a very large quantity of them does not accept to be removed, and each one in this case takes several times the time to clear one that is accepts. I had to give up because it would have taken many hours. Previous versions of windows would accept removing all keys, but not Vista. so now, I’ll have to try the other suggestion and start by slipstreaming SP2.
Of course, I am very grateful for the real good will and the help being kindly provided and I will go on following all suggestions as I can. This now will take me over one day and as I might be absent, maybe more days. I’ll be back with the results hoping it works.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Ardneh. I can´t do it for the moment because I need a lot of time without interruption, but I was checking a few operations and on the http://www.vistax64.com/tutorials/230249-sliptream-vista-sp2.html tutorial nothing happens when I press Ctrl+Shift+F3 on points 2 and 3. Is there anything that might not let me do it, and is not mentioned on the tutorial. please? :huh: Thks.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
