Please Help Decipher and solve my BSOD Problems !! Thanks
LBJ
I have gotten 3 BSOD's in a row now and have no idea why I have gotten this ... I ran the debugging tool and came up with the dump info from the last time I got it ... If anyone can give me an idea as to why this is happening I would greatly appreciate the help ... Thank You !!
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff80002058000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 49e0237f
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
fffffa8005e00000
FAULTING_IP:
nt+2e2fde
fffff800`0233afde ?? ???
MM_INTERNAL_CODE: 2
CUSTOMER_CRASH_COUNT: 3
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80002112a5a to fffff800020b2450
STACK_TEXT:
fffffa60`08aec3f8 fffff800`02112a5a : 00000000`00000050 fffffa80`05e00000 00000000`00000000 fffffa60`08aec4e0 : nt+0x5a450
fffffa60`08aec400 00000000`00000050 : fffffa80`05e00000 00000000`00000000 fffffa60`08aec4e0 00000000`00000002 : nt+0xbaa5a
fffffa60`08aec408 fffffa80`05e00000 : 00000000`00000000 fffffa60`08aec4e0 00000000`00000002 00000000`00000000 : 0x50
fffffa60`08aec410 00000000`00000000 : fffffa60`08aec4e0 00000000`00000002 00000000`00000000 00000000`00000000 : 0xfffffa80`05e00000
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
nt+2e2fde
SYMBOL_NAME: nt+2e2fde
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
MODULE_NAME: nt
fffffa8005e00000
FAULTING_IP:
nt+2e2fde
MM_INTERNAL_CODE: 2
BUGCHECK_STR: 0x50
CURRENT_IRQL: 0
STACK_TEXT:
FOLLOWUP_IP:
nt+2e2fde
If u upload the minidumb.dmp file, it would be easier to sort out the issue
By default the file will be stored in c:\windows\minidump
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
Thank you for looking into my problem everyone !! Here are the minidump files in .zip form .... I hope this can help to further diagnose the issue !! I would also like to add that I have figured out that the issue happens specifically when I am using my mlb.com stream ... I have paid to watch baseball games online and have never had any issues doing so until now ... When I start the game it comes on for some time and then lockes up and goes to a BSOD immediately .... Thank you for any help you provide ....
Are u using Kaspersky AV software with any tv plugin on your browser?....
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
delphin is right. The dump files point to kl1.sys - a component of Kaspersky.
I seem to have done these files before (I recall the MLB streaming stuff) - is this the same set of dump files?
I do not recommend using Internet Security applications from any vendor - but the Kaspersky Antivirus is a good program.
There's also some other older drivers on your system that you may want to update:
Code:
nvraid.sys   Wed Jun 06 16:34:01 2007
L8042Kbd.sys Wed Apr 11 19:29:56 2007
pcouffin.sys Tue Dec 05 09:39:30 2006
ezplay.sys   Mon Apr 30 06:08:55 2007
npf.sys      Tue Nov 06 15:10:02 2007
Here's a summary of the dump files:
Code:
Built by: 6002.18005.amd64fre.lh_sp2rtm.090410-1830
Debug session time: Fri Jul 17 22:17:42.816 2009 (GMT-4)
System Uptime: 0 days 6:27:10.969
BugCheck 50, {fffffa60037d1008, 0, fffff800020c8f63, 0}
*** WARNING: Unable to verify timestamp for kl1.sys
*** ERROR: Module load completed but symbols could not be loaded for kl1.sys
Probably caused by : kl1.sys ( kl1+59621 )
PROCESS_NAME:  mlb-nexdef-auto
Debug session time: Fri Jul 17 22:29:07.922 2009 (GMT-4)
System Uptime: 0 days 0:10:13.685
BugCheck 50, {fffffa8009a00000, 0, fffff800022f9fde, 2}
Debug session time: Fri Jul 17 22:47:55.894 2009 (GMT-4)
System Uptime: 0 days 0:17:58.031
BugCheck 50, {fffffa8005e00000, 0, fffff8000233afde, 2}
