Please Help Decipher and solve my BSOD Problems !! Thanks
LBJ
I have gotten 3 BSOD's in a row now and have no idea why I have gotten this ... I ran the debugging tool and came up with the dump info from the last time I got it ... If anyone can give me an idea as to why this is happening I would greatly appreciate the help ... Thank You !!
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff80002058000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 49e0237f
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
fffffa8005e00000
FAULTING_IP:
nt+2e2fde
fffff800`0233afde ?? ???
MM_INTERNAL_CODE: 2
CUSTOMER_CRASH_COUNT: 3
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80002112a5a to fffff800020b2450
STACK_TEXT:
fffffa60`08aec3f8 fffff800`02112a5a : 00000000`00000050 fffffa80`05e00000 00000000`00000000 fffffa60`08aec4e0 : nt+0x5a450
fffffa60`08aec400 00000000`00000050 : fffffa80`05e00000 00000000`00000000 fffffa60`08aec4e0 00000000`00000002 : nt+0xbaa5a
fffffa60`08aec408 fffffa80`05e00000 : 00000000`00000000 fffffa60`08aec4e0 00000000`00000002 00000000`00000000 : 0x50
fffffa60`08aec410 00000000`00000000 : fffffa60`08aec4e0 00000000`00000002 00000000`00000000 00000000`00000000 : 0xfffffa80`05e00000
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
nt+2e2fde
SYMBOL_NAME: nt+2e2fde
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
it is a driver failure, not sure which driver at the moment.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
This is an error involving access to the memory pool functions of the Windows Memory Manager. As fadedrs states, it's usually due to a corrupt driver.
But, corrupted memory can also cause this - whether it be your physical RAM, your pagefile, your video RAM, or even your CPU cache.
I'd suggest running the built in memory diagnostic for Vista: BC - Vista Memory Diagnostic
Also, navigate to C:\Windows\Minidump and zip up the minidump files there. Then upload the .zip file with your next post so we can massage the dump files a bit more.
More info on using the debugger is here: Diagnosing Bsod's (originally posted 02Oct08) - Vox
Thank you for looking into my problem everyone !! Here are the minidump files in .zip form .... I hope this can help to further diagnose the issue !! I would also like to add that I have figured out that the issue happens specifically when I am using my mlb.com stream ... I have paid to watch baseball games online and have never had any issues doing so until now ... When I start the game it comes on for some time and then lockes up and goes to a BSOD immediately .... Thank you for any help you provide ....
You stream MLB.COM! I'm envious (and a rabid Red Sox fan!)!
The streaming will affect your video, audio, and network/protection systems (and they all use the memory manager). So, please run the memory diagnostic that I recommended earlier.
And...it appears we may have gotten lucky with this one. All the errors point to kl1.sys as being at fault - and always while working in the MLB stream. This driver belongs to your Kaspersky protection package.
My advice will depend on if you have Kaspersky Antivirus or Kaspersky Internet Security installed:
Kaspersky Antivirus (KAV) installed:
- Download a new copy of KAV from the Kaspersky website
- Uninstall your current copy of KAV
- Reboot
- Install the freshly downloaded copy of KAV
- Update it immediately.
Kaspersky Internet Security (KIS) installed:
I see a lot of problems with Internet Security applications - and not just Kaspersky. When they work, they work well - but when they mess up it's sheer torture getting the problem located and fixed. As such, I do not recommend the use of Internet Security applications from any vendor.
Should you want to keep KIS anyway, follow the same steps as for KAV.
I would recommend another antivirus program, such as the free Avast Antivirus along with an anti-spyware application of your choice and the Windows Firewall (others may feel this is insufficient and recommend more protection - but that's your choice).
Here's a summary of the BSOD reports:
Code:
Built by: 6002.18005.amd64fre.lh_sp2rtm.090410-1830
Debug session time: Fri Jul 17 22:17:42.816 2009 (GMT-4)
System Uptime: 0 days 6:27:10.969
BugCheck 50, {fffffa60037d1008, 0, fffff800020c8f63, 0}
*** WARNING: Unable to verify timestamp for kl1.sys
*** ERROR: Module load completed but symbols could not be loaded for kl1.sys
Probably caused by : kl1.sys ( kl1+59621 )
PROCESS_NAME:  mlb-nexdef-auto
Debug session time: Fri Jul 17 22:29:07.922 2009 (GMT-4)
System Uptime: 0 days 0:10:13.685
BugCheck 50, {fffffa8009a00000, 0, fffff800022f9fde, 2}
Debug session time: Fri Jul 17 22:47:55.894 2009 (GMT-4)
System Uptime: 0 days 0:17:58.031
BugCheck 50, {fffffa8005e00000, 0, fffff8000233afde, 2}
i would agree with usasma it does seem to be a issue with kaspersky.
do as he suggested and hopefully that fixes the issue, if not let us know.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
