Corsair XMS3 DDR3 1600 MHZ OCING HELP
MDA400
Nvidia and Intel
Power User
I need a bit of assistance or advice on how to or if i can even OC my 8 Gb DDR3 dual channel Corsair XMS3 1600 MHZ CAS 9 DHX ram to 2000 MHZ.
I am running the ram on a 790i FTW DIGITAL PWM from EVGA with a Q6600 at 3.6 Ghz. I have the ram at 1800 Mhz with timings of 8-8-8-24-T2
with a voltage of 1.9 STABLE. Of course, my board is rated for DDR3 2000 MHZ ram with EPP 2.0. But, ive seen it done with none EPP G skill 1600 mhz ram as well.
if any of you know the right voltage, Timings, or any other clocks on my other components that i should change to get to 2000, please explain and ask others if they'd know as well.
I know if you say "whats the use for Ocing that DDR3? you wont get any performance benefits due to the bottlenecking of the old and ancient FSB bandwidth.". I am only doing this to see if i can actually reach 2000 mhz without having a memory error/BSOD that screws up my system.
    JUST ME/Custom Built
    Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
    EVGA NFORCE 790I SLI FTW Digital PWM
    8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
    2x GTX 480's w/ Koolance VID-NX480's
    Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
    Acer P243W 24" Premium Series
    1920 x 1200
    Seagate Barracuda 7200.11 1 TB HDD 32mb cache (3 Platters, 6 Heads model)
    Ultra X4 1050W PSU 76A Rated 12V SLI
    Antec 1200 Full tower ATX case
    x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
    Logitech LX310 2.4Ghz Wireless Laser Mouse
    Logitech LX310 2.4 Ghz Wireless Keyboard
    32mb Download, 12mb Upload from Comcast
    300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
Just increase the RAM speed manually to 2000. Set the timings to default and go in small increments. If your PC fails to boot, then just increase the voltage.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
unless i get a BSOD from the memory like " memory exception error" or "paged file in a nonpaged area" and my system completely starts shutting down different processes and crashes. i want to know for sure if there is any way to get it there stable.
    1920 x 1200
