Problems upgrading from 32 bit to 64 bit!
fryzie
Hi guys.. I already had Vista 32 bit which was preinstalled on my computer.
I am wanting to upgrade to 64 bit which I have the CD of.
But whenever I run the setup I get
"the version of this file is not compatible with the version of Windoes youre running. Check your computers system information to see whether you need an x86 or x64 version of the program, and then contact the software publisher".
Does anyone know how I can still the 64 bit version still?
I think what it is trying to do is read the disk and use the utilities on it but because it is the 64 bit and not the 32 bit (that is installed) and it can't do it. You should still be able to install 64 bit. Just gotta put the disc in, reboot, and boot from disc when it asks.
I am not positive but I think that you need to do a fresh install to make it x64. Which means reformatting your hard drive and losing the data you don't have backed up. If thats not a problem then go ahead and do it. If it is you may want to wait to see if someone else has any input on that.
    Intel Core 2 Quad Q9550 Yorkfield 2.83GHz
    EVGA 780i FTW
    G.SKILL 4GB (2 x 2GB) DDR2 1066 (PC2 8500) Dual Channel
    Dual BFG 8800gt OC 512MB in SLI
    1440 x 900
    WD Caviar Blue 640GB
    Antec CP-850 (850 Watts)
    Antec 1200
    ZALMAN CNPS9700 LED 110mm
    Razer Deathadder
    Razer Lycosa Mirror Ed.
    5MB
argh im trying to boot from cd during setup, but it just doesnt load.
ive even tried setting it to only boot from cdrom... yet the hdd still loads instead
is this vista cd damaged?
I hope it's a dvd.
Tipher is correct - you can't do an upgrade installation if you are changing bit versions - you need to clean install.
When you try to boot the dvd - how far do you get?
Start the machine - watch the black screen with white writing - you will get something like
F2 for setup
F11 for boot menu
Select F11 ( your F number may be different)
A pop up boot menu will appear after a few seconds.
Arrow down to cdrom drive - put the dvd in the drive - close it - press enter.
A few seconds later it should say " press any key to boot from cdrom drive" - press enter again.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
You cant upgrade from 32 to 64 you have to do a clean install.
you should be able to boot from the DVD do you see "PRESS ANY KEY TO BOOT FROM CD/DVD"?
if you do not your bios is not setup correctly to boot from the CD/DVD drive first.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
i got no idea what is going on, but it is not booting from the cdrom
i do have a 64 bit windows XP...
if i was to install that, would i then be able to install the 64bit vista by just going through the cdrom drive -> my computer
I can't say I've ever installed an OS by booting into the already installed OS and running an installer from the CD drive, I've always booted from the disc. Also I'm pretty sure you cannot downgrade to XP from Vista.
In your BIOS what is first in your boot sequence?
And some common sense questions I just feel compelled to ask:
What type of processor do you have?
Where did you get your vista x64 disc?
    Sager NG2096
    Intel P8700
    4 Gigs
    9600M GT
    Samsung PN50A550
    Primary 1680 X 1050, Secondary 1920 X 1080
    Logitech MX Revolution
    Satalite :-(
    Running SUSE, Solaris, Kalyware, and BSD through vmware whenever the mood strikes
that would be correct.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
you can download this file from microsoft (and "run" it) and find out if you can upgrade:
www.microsoft.com/windowsvista/get ready/upgrade advisor
    HP
    AMD X4 Phenom 9550
    6gb
you cant do an upgrade from 32 to 64 so that will not work.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
did you go into the bios and change the boot order to boot from the cd/dvd first
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
