Going Crazy, hotkeys or keyboad issue?
berrylover
I bought a new dell studio laptop and it came with Windows Vista. I just bought it two weeks ago and its driving me nuts. TO the point that I don't even use it. When the letter "h" is typed in, history opens up. When the letter T is opened up, a new tab opens. THis is so frustrating. I searched the forum and there was a similar post to remove hotkeys. There was a link I downloaded and it was supposed to remove the hotkeys from registry. It did not.
Any help? Please! Thanks.
Sounds like the ctrl key on the keyboard is jammed.
Try pressing it a few times and see if that helps.
If it is actually damaged - take it back to the shop and get a new one.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Its not jammed from the feel to it. Another thing it does is when Im using the mouse pad, it increasse/decreases the size of the screen zoom. Thanks!
That confirms it . The ctrl key function is on all the time. Even tho. the key itself moves.
Take it back to the shop.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
also, look down near the clock on the taskbar for an icon that might be related to a hotkey program. and check the "ease of access" settings in the tools menu. you could also look in the quick user guide that probably came with the laptop.
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
In addition to Kword's suggestion, you might see if it is Sticky Keys that is on causing this.
Ok. I'm having the same problem and it's really piddling me off. No matter what I do and I'm not even pressing the cntrl+ botton! Press H and it pops up History, press T new browser window, printer menu etc. I'm going NUTS, and don't even want to use the damn laptop anymore, oh and it's a Dell too. They must suck since I've noticed this problem and the Dell name. Anyways, I downloaded a program that is SUPPOSED to work and disable damn hotkeys and what do you know it doesn't have any effect. I'm using Windows7 btw. :mad: I don't see how the stupid hotkeys serve any purpose really. They are more of a nuisance than anything. So frustrated!!
