Battery/Adapter Question
shortmantuff
I have a laptop and to conserve the battery life, I tend to take the battery out and just plug only the adapter in. Is this bad for the computer or the adapter?
    Toshiba Satellite A215-S4757
    2048MB DDR2 SDRAM
    ATI Radeon® X1200 128MB-319MB
    15.4” diagonal widescreen TruBrite®TFT LCD display at 1280x800 native resolution (WXGA)
    250GB (4200RPM); Serial ATA hard disk drive
No harm done. The only thing to worry about is because you are taking the battery out you have a greater chance of bending the prongs for the battery connection. Another thing to watch out for is that if it gets unplugged...you are hosed (as this will cause it to immediately shut off). Other than that it's fine.
Some newer model laptops actually come with an option that when it is plugged in, you can disable battery charging. So the power just goes directly to the computer instead of through the battery then to the computer.
Hope that helps.
    Intel Core 2 Quad Q9550 Yorkfield 2.83GHz
    EVGA 780i FTW
    G.SKILL 4GB (2 x 2GB) DDR2 1066 (PC2 8500) Dual Channel
    Dual BFG 8800gt OC 512MB in SLI
    1440 x 900
    WD Caviar Blue 640GB
    Antec CP-850 (850 Watts)
    Antec 1200
    ZALMAN CNPS9700 LED 110mm
    Razer Deathadder
    Razer Lycosa Mirror Ed.
    5MB
Hope that helps.
Oh, that's sweet. The newer models part. Are these fairly recent models? Like 2009? Or can some 2008 have that option?
    2048MB DDR2 SDRAM
2009 is all I know of, I suppose it is possible on a 2008 but I don't know. We just ordered one for a guy at work that has it. A Dell Latitude E4300.
    EVGA 780i FTW
    1440 x 900
    Antec 1200
    Razer Deathadder
    5MB
