Can a PSU cause heat problems?
Exidium
I have been having alot of problems with a stock gateway lx 6810-01
Problem is the cores are running at like 60c and I know thats above normal.
My question is, can a stock PSU have anything to do with the cores running too hot?
only if the cpu fan is not getting enough power from the psu.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
What would be considered the CPU fan? We bought a new heat sink thats huge and says it runs around 2200 rpm's at max with a little knob you turn, but it runs at 900 rpm's at max.
So, PSU issue? Or heat sink issue?
Thermaltake - 120mm CPU Cooling Fan - CL-P0401
As you can see, the fan is built into the heat sink. The only other fans I see in the computer are 1 on the GPU and 1 on the PSU.
The only thing I can think off is that the PSU is super cheesy and not capable of handling the mobo + other hardware and it is suffocating itself.
That or your case is not well ventilated and/or you need to add a couple of fans for more airflow
Third, you can get into the BIOS and manually adjust your fans to 100% so they are blowing at max all the time, it will get noisier but it will cool down your temps.
Last thing I can say is perhaps you used to much, to little or no compound at all when you installed the heatsink.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
And how would one go about manually changing all of my fan speeds? I'm looking in bios on that gateway and I see no such option.. The only relative options are Smart fan with an option to enable or disable and quiet startup.
I don't see anything else fan related.
what is the model / power rating on your psu.
also download a program called speedfan and you can really see what the rpms are at
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
OK, is "Smart Fan" disabled or enabled? If I am not wrong...
Enable = The Bios will dictate how much % speed to let the fan run according to heat temps.
Disable = No matter what, the fans will run at 100%... This is what you want!
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
did you fit the heatsink / fan correctly? what paste did you use? how much did you use?
have you tried removing it , cleaning and reseating?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
fadedrs: We have speed fan already, both the bios and speedfan report the low 900 rpm's. It's a LiteON ps-6401-3 psu at 500w.
AstaLaVista: It was enabled, I disabled it yesterday only to find that the RPM's all ran the same.
Archie123: Yes we mounted it correctly with both the stock one, and the new one.
We used this exact brand of Thermal Compound. Dynex® - Silver Thermal Compound - DX-STC 100
At first we applied too much after watching a ton of vidoes about proper application of thermal compund.. After wards we put a little bead in the the center and set the heat sink on it again and let it spread.
(We used 99% isopropyl alcohol to clean after each application)
I believe too much is bad and too little is bad so we just did the "blob technique" according to a few videos.
(Just read a review on this paste, apparently according to one person it takes about 3 days to reach maximum heat transfer)
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Before we blame the possible faultyness of the fan, could we say that the PSU could also be the reason for the low rpm's?
I wanna weed out everything before we take that hunk of metal out and get a new one and have the same problem.
The old heatsink with it's fan ran at 2200 rpm's but it plugged into a 4 prong looking little slot in the mobo, this new one plugs into a 3 pronger sticking out of the mobo.
mine has three also. with a 500 psu you should be ok i would say a faulty fan.
also mine came with a wired remote that i could turn the fan up or down in speed from the outside of the case.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Yeah a knob came with this one that has a low and high setting, low yields 400ish rpms, and high yields 900 rpms.
Wierd part is with the stock heat sink, we took it off too and applied new thermal paste correctly, put it back on and it had a fan mounted on it that ran at 2200 rpm's yet still showed the same heat on the cores as this big thing, coincidence?
i would say it is the fan something is wrong with it. or it is pluged in wrong to the motherboard. that could cause the low rpm
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
No, it's correct, it's plugged into the only space on the mobo that it can properly fit. I guess we will take it back tomorow and exchange it for another. What happens if it's the same deal then what should we do?
i would try a different kind of fan/heatsink combo, did you get it at bestbuy?
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
What does the fans 3 pin header on the mobo say? ie PWM, CPU, PWR
If it's a CPU fan, it should be connected to either CPU or PWM.
Have you tried plugging the fan into the 4 pin slot? A 3 pin will still work on a 4 pin slot.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
it should match up will the clip on the cpu fan power cord. it should go into it only one way with one pin left out.
should be four pins sticking out of the mobo with a piece of plastic sticking up behind them the power cord should sit right into it and kind of wrap around the plastic piece sticking out.
sorry hard to explain.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
