please help power loss during system restore
sarahjo
Hi, im wondering if anyone can help me, i had to do a system restore which i've done before with no problems, this time however when the comp started back up we had a power cut and now when i turn on comp all i get is a black screen even starting in safe mode etc all i get is the microsoft logo at the bottom of the screen and it just goes back to the black screen, the only thing working is the cursor
can anyone PLEASE HELP!!! :cry:
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Hi Ted thanks for the welcome
I tried it with the disc but nothing happened, then noticed its an anytime upgrade disc is that why it didn't work, iam a real novice not even sure im putting the disc in at the right time :rolleyes:
You should be using a restore disc, not an anytime upgrade disc. Do you still have these?
    Dell XPS M1330
    Intel Core 2 Duo
    3GB
No, the comp was built and vista put on for me then after about a year it kept saying it was counterfeit, so i went to the microsoft website and downloaded a genuine copy, and the discs they sent through only included an anytime disc for the 32 and 64
In many cases you can contact the manufacturer to get replacement discs. However, since it seems like your system was built (and not by you) you might want to get in touch with Microsoft about replacement discs:
Microsoft Help and Support
    Dell XPS M1330
    Intel Core 2 Duo
    3GB
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
