Solved Help Sidebar won't start
Fastboy42
Banned
Could anyone fix my sidebar?
Sidebar Crashes as soon as I start it. I have tried Shawn's Toturials ,but sidebar still doesn't work.
When you click more it says this
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: sidebar.exe
Application Version: 6.0.6002.18005
Application Timestamp: 49e02551
Fault Module Name: kernel32.dll
Fault Module Version: 6.0.6002.18005
Fault Module Timestamp: 49e037dd
Exception Code: e0434f4d
Exception Offset: 0003fbae
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 5129
Read our privacy statement:
Microsoft Online Crash Analysis
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
    eMachines D620 (laptop)
    AMD Athlon Processor 2650e 1.60GHz
    ACPI x86-based PC
    (RAM) 1.00GB
    Internal DAC (400MHz) - memory: 382 MB
    Realtek High Def Audio
    ATI Radeon X1250 - 14"
    1280 x 800 (60Hz)
    ST9160310AS ATA Device
    Stealth~graphite
    Synaptics PS/2 Port Touchpad + Microsoft Optical Mouse 500
    Launch Manager Version 2.0.02
    Cable/wireless-router
    NO WEBCAM - (privacy)
It did'nt work,it still crashes.
I've done sfc \scannow , deleted settings , tried what that ross guy said ,but it still doesn't work.
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
    ACPI x86-based PC
    (RAM) 1.00GB
    1280 x 800 (60Hz)
    Stealth~graphite
Thankyou kikidee
None of your solutions worked ,but I did find out myself how to fix it. I just copied the windows sidebar folder to my documents then deleted the original and ran sfc /scannow.:D
Thankyou for your help anyway.:D
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
---THANK YOU for the info, I will save this into my thread-files also for future use. (I did not realize that you can actually copy 'program' files into the documents in a pc to save, good idea!)---
peace
    ACPI x86-based PC
    (RAM) 1.00GB
    1280 x 800 (60Hz)
    Stealth~graphite
Hi Fastboy, close sidebar. Open taskmgr, end sidebar.exe process, open windows explorer and type
%localappdata%\microsoft\Windows Sidebar
Rename the settings.ini file. Restart the computer.
Open Windows sidebar again.
let us know if it still crashes.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Thankyou Dinesh ,but I've already fixed it.:)
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Glad that its working now. But i still posted this solution may be if someone else is in need of it.
    Compaq
    15"
    160 GB WDC
