I recently bought a HP pavillon notebook, and I want to create recovery disks with "Recovery Manager ---> Recovery Disk creation".
I'm using DVD-R disks, the Recovery Manager tells me I need 3 disks. After the creation of the first disk, the Recovery Manager ejects the disk tells me (in french):
Creation du disque 1 sur 3 réussie
Reinserez le disque que vous venez de creer et fermez le plateau du lecteur.
which means:
disk 1 of 3 successfullly created
Insert the disk you just created and close the drive tray.
I did that, but nothing happens, the program will do nothing and does not proceed to ne next step; the creation of disc 2.
Thanks.
Gilberto
which means:
Thanks.
Gilberto
