Annoying problem driving me crazy. Help!!!
TheHermit1971
My Vista Home Premium installation has this annoying problem that I'm not able to get rid off no matter what I try. It freezes during the loading process. If I boot in safe mode it loads correctly. When it freezes the hard drive's front light keeps flashing and I can keep hearing sounds as if it was loading normally but it's really hanged. Does somebody has any idea about how to solve this?
Have you installed any new hardware or software? Have you checked your bios to see if anything has changed there? if you can get to safe mode, have you checked your drive for physical problems?
That's all I can think off with so little info on your part... sorry. :(
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
