My Home Premium 64 Bit Got ntdll.dll Problem!!!
danxangel
I've just got this Error for a few days and tried so many ways to solve it, but it seems to be useless.
Problem signature:
Problem Event Name: APPCRASH
Application Name: patcher_1.exe
Application Version: 1.0.0.1
Application Timestamp: 49055f74
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a783
Exception Code: c0000005
Exception Offset: 00023592
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 1573
Additional Information 2: 8174477e3f239fdb2eb28590ffa32700
Additional Information 3: f1c9
Additional Information 4: f7c0aa8817dca409d416936c036f5b41
On the first day, i tried to reinstall windows and install this software again. [ Still that error ]
The next nay, i tried to install this software on my laptop. [ Still it ]
And after checking CMD, i tried on both of mine. [ still it ]
The last day, tried to download that software again and reinstall it. [ still the same ]
i spent 3 days to find out what's going on! But nothing's gonna change or be better!
I'm really confuse right now. Does anyone know how to solve this error ? Please help me!
    Gateway 6200-1 (Upgraded)
    AMD Phenom II x4 3.0 Ghz
    Gateway RS780
    ATI Radeon 4870
    Creative
    Samsung Syncmaster 22'
    750 GB Hitachi
    Zalman, Thermaltake
Patcher_1.exe, whatever that may be, is likely buggy. NTDLL.DLL is just about the most important DLL in the entire operating system, and it has the job of preventing apps from doing silly things.
In this case, the timestamp on patcher_1.exe is "Mon, 27 Oct 2008 06:28:04 UTC" (49055f74). Perhaps a newer version may contain a fix for the problem which causes this crash.
so obviously the software your trying to install is trying to do silly things ;) ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Should i check my hard drive ? If sth's wrong, i could check it!?
    Gateway RS780
    ATI Radeon 4870
    Creative
    750 GB Hitachi
    Zalman, Thermaltake
There is no indication so far that the problem is anything but a bug in patcher_1.exe. You've tested it on multiple machines and from what I understand it is crashing the exact same way. Hence, while checking hard drives won't hurt, it's unlikely to help either.
What is "patcher_1.exe" anyway? You mentioned you're downloading it from somewhere. If you can supply a link, I'd be curious to take a look.
Oh, this is the game which my little sister likes to play most. Btw, thanks for helping me ^^
I dont know what's wrong with this one? Cause several months ago, it worked well.
Here's the link:
http://downloadhcm.au.vtc.vn:2180/Audition_FULL_6060.exe
    Gateway RS780
    ATI Radeon 4870
    Creative
    750 GB Hitachi
    Zalman, Thermaltake
Here's the link:
I'm not sure I understand because you originally said "patcher_1.exe" crashes when you try to run it. How is that related to "Audition_FULL_6060.exe"?
Also, just to confirm, all this stuff is fully legal, right?
yeah, that's the full version of the game, include patcher_1.exe.
Patcher_1.exe is a game launcher, and that game is 2.16 gb total.
when u set up the game, check the folder you will see the patcher_1.exe.
By the way, this is the result when i check CMD. Patcher_1.exe and Patcher_2.exe
sfc /SCANNOW
sfc /VERIFYFILE=c:\windows\system32\kerne132.dll
sfc /SCANFILE=d:\windows\system32\kerne132.dll /OFFBOOTDIR=d:\ /OFFWINDIR=d:\windows
sfc /VERIFYONLY
And this is the patcher_2.exe error:
Problem signature
Application Name: patcher_2.exe
Application Timestamp: 485713b2
Fault Module Name: StackHash_c453
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c00000fd
Exception Offset: 74e89b84
Locale ID: 1033
Additional Information 1: c453
Additional Information 2: abcc8f7853b48d9807d6d51eb1fa5df9
Additional Information 3: c453
Additional Information 4: abcc8f7853b48d9807d6d51eb1fa5df9
Extra information about the problem
Bucket ID: 1264208307
Sometime with patcher_2.exe, it got a problem BEX and the stackhash changed too. I dont really remember the other stackhash numbers.
I have tried to turn off DEP too, but it didn't work.
Notice :That game has 2 patchers.
    Gateway RS780
    ATI Radeon 4870
    Creative
    750 GB Hitachi
    Zalman, Thermaltake
Sorry mate, 2+ GB is beyond the abilities of my humble internet pipe.
The numbers in those errors you posted are not enough to allow for direct troubleshooting, but here's a few random thoughts:
- The CMD screenshot shows sfc.exe complaining because it doesn't understand your syntax... you left a space between the slash (/) and the SCANNOW. Instead of "/SCANNOW" you typed "/ SCANNOW". If that was intentional (why?), don't worry about this point.
- There's no default DLL called "kerne132.dll". It's KERNEL32.DLL - that's an 'L', not a '1'.
- If you experience the same crash(es) on multiple machines, that greatly lessens the chance that file corruption is the cause. It would be highly improbable for two separate file systems to happen to be corrupted in precisely the same way.
- It may be far faster to email the game vendor and to ask them for help. Otherwise, if you've got to troubleshoot by trial-and-error this could take a while.
I'm newbie at this thing. Anw, thanks for helping me, HSO4.
Maybe i better choose a different game for her, this one really makes me tired ^^
    Gateway RS780
    ATI Radeon 4870
    Creative
    750 GB Hitachi
    Zalman, Thermaltake
