Building my PC for first time.. HELP!
iTragedy
You heard right. I am building a PC for the first time.
I have a laptop and desktop, but the desktop is five or so years old.
I need a new one, and retail is too expensive, but if a built one is even more expensive, I don't care - I make it and can upgrade it.
So, I am running into some problems.
I don't know a lot about hardware, so I need help here.
Some questions:
How do I know what hardware my motherboard supports?
I have seen computer cases with a component at the front that shows the stats (CPU Usage, RAM Usage, Hard Drive Usage, and a lot more) Is it part of the case? If not, where can I get it? What is it?
Where would I go about getting RAM with LED's?
Thats all for now, but I could add more later.
Thanks!
When you look at motherboards to buy, read the technical specs and it should tell you a lot about it, such as the CPU socket type, RAM slot types etc.
The CPU socket type needs to be matched to the processor it's supports i.e. a motherboard with a socket 775 is for socket 775 processors, such as a Core 2 Quad processor. AM2, AM2+ and AM3 are AMD processor sockets, and socket 1366 are Intel's new i7 processor sockets. If you buy a heatsink and fan for a processor, you just need to find one that is compatible with the motherboard socket, but they're easy to find as all modern ones will support current socket types.
RAM slots are simple and are either DDR2 or DDR3. You can't mix and match, so DDR2 slots can only hold DDR2 RAM sticks, same for DDR3.
You will also need to look at the expansion slots, like the PCI slots. Graphic cards run on PCI-E slots, so look for either PCI-E x16 or PCI-E 2.0. PCI-E 2.0 graphic cards can run in PCI-E x16.
Other things will most likely be on the motherboard, such as SATA ports for SATA hard drives and SATA DVD drives, though most websites have each piece of hardware described accuratley. Like if you're looking for a SATA hard drive, it should clearly say SATA in the technical specifications or something.
The components that display CPU usage etc are multi-function panels and fan controllers. You will most likely need to buy this seperatley.
Only RAM I know of with the LEDs are Crucial Ballistic Tracer RAM, but they're only small LEDs to show RAM usage. You'd be better off just buying normal RAM then buying something like OCZ's fan cooler that has blue LED fans on it for a better effect.
Hope this helps. It's a brief explanation about everything, but if you have any more questions then just fire away :)
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Thanks so much Everlong!
I found my hardware and it all seems compatible.
What do you think of this build:
PC Case
Graphics Card
Hard Drive
CD-ROM Drive
Power Supply
RAM
Processor
Multi-Function Panel
Accessories:
Lighting
Storage
Also, could you help me decide which keyboard to get?
By the way, I've seen some awesome fans with lights, but do you think you could point me to some good places where I could get them? I was hoping to get two 120mm fans that both light up.
Potential fans:
120mm
CPU Fan
One last thing: Whats better, water cooling or fan cooling, and which would you recommend?
Thanks so so far and for the future :D
It looks like a nice build :)
Just a couple of things I'd change is the CPU Fan first, I'd try and get something like a Zalman 9700, and that RAM too, I'd maybe try and get 800MHz instead of 667MHz, but that 667MHz will still be fine if you're happy with it.
I'd stick with fan cooling myself at the moment. It's still adequate for modern processors, and would only really get water cooling if I overclocked a lot.
And both of them keyboards are good, though personally I use a G11 keyboard, which I love. If you're wanting to game then try and get a wired gaming mouse as well, as the two keyboards you've chosen are gaming keyboards. Though these are just a few things I'd choose, but at the end of the day it's your PC :)
    ASUS Xonar DX
    100Mbps
Water cooling is superior but seeing as it's your first build, I'd start with air cooling :)
I have the Cyborg keyboard and overall I'm happy with it. If I had to nitpick, I'd prefer if it had some better anti-ghosting (simultaneous key-presses) and the macro keys could be closer to the regular keys. They certainly do come in useful both in games and at the desktop though.
On the plus side, the drivers are good and once you work out the profile editor, it works well. Plus the keyboard looks good in the dark ;)
For LED case fans, I have 6 Zalman ZF-M3's. They push a decent amount of air, look good and aren't too loud. (more soft whoosh than whine) Avoid Antec Tri-Cools if you can.
If you're going to get a 4870, I'd highly suggest a 1GB model for high res texture settings. 512mb is fine at medium, but performance can suffer signifigantly when high res textures are used in some games.
As Everlong suggested, grab some 800mhz or even 1066hz Ram.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
hmmm looks like a very nice new build :D..... my one recommendation.... on top of the others.... is try to get the phenom II..... it might be a little more but it is well worth the extra money..... the 940 or the 920 at most is only 100 more.... :D
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
how much total are you looking to spend?
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    6gb MUSHKIN DDR3 1866
    TWO x EVGA NVidia GTX 285
    Soundblaster Extreme
    ASUS 24inch 2ms LCD
    1920x1080
    4 x OCZ Vertex 60GB, 1 x Western Digital Velociraptor 300GB, 1TB Western Digital Caviar Black
    Corsair 1000W
    Coolermaster HAF 932
    Water cooled
    Microsoft Regular USB w/wheel
    Saitek Cyborg Deluxe
    Cable 15mbps
I can probly build you something much better for around the same money spent on all of that.... if your primary is gaming, i would step away from the AMD, and go with an INTEL.... AMD is not doing too hot these days.
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
Everlong: How does this sound?: RAM
Hmm, Maybe I might get the G11, its just a little too pricey in addition to the build.
Smarteyeball: How about this card?: Card
Smokkinu: Sadly, I can't afford Intel right now, and this is a comb. You buy the motherboard and it comes with the AMD Processor. I really wanted a quad, so I couldn't go with Intel because its 100 or so more.
What is your price range? just give me that and i can help you out...
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
Also, tell me what you NEED in a new build.... IE: Case, Monitor, Keyboard, Mouse... etc etc...
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
I just built you a complete core i7 920 system for under $1500 w/out monitor and keyboard...
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM Item #: N82E16827136152 Return Policy: 30 Day Return Policy Protect Your Investment (expand for options27-136-152|hide options27-136-152)
Service Net Replacement Extended Warranty Plan The product will be replaced and shipped directly to you at no charge(more info27-136-152.0.18)
  • 1 year: $7.99
  • 2 year: $12.99
$24.99 . .
11-129-021-TS
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail Item #: N82E16811129021 Return Policy: Manufacturer Warranty -$20.00 Instant
$139.99 $119.99 . .
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM Item #: N82E16822136322 Return Policy: 30 Day Return Policy Protect Your Investment (expand for options22-136-322|hide options22-136-322)
Service Net Replacement Extended Warranty Plan The product will be replaced and shipped directly to you at no charge(more info22-136-322.0.18)
  • 1 year: $29.99
  • 2 year: $49.99
$229.99 . .
EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail Item #: N82E16814130434 Return Policy: Limited Non-Refundable 30-Day Return Policy -$25.00 Instant
$20.00 Mail-in Rebate $204.99 $179.99 . .
RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Modular LED Power Supply - Retail Item #: N82E16817152035 Return Policy: 30 Day Return Policy Protect Your Investment (expand for options17-152-035|hide options17-152-035)
Service Net Replacement Extended Warranty Plan The product will be replaced and shipped directly to you at no charge(more info17-152-035.0.18)
  • 1 year: $10.99
  • 2 year: $17.99
-$10.00 Instant
$25.00 Mail-in Rebate $79.98 $69.98 . .
Crucial Ballistix Tracer 1GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory (with LEDs) Model BL12864TB1337 - Retail Item #: N82E16820148296 Return Policy: Standard Return Policy Protect Your Investment (expand for options20-148-296|hide options20-148-296)
Service Net Replacement Extended Warranty Plan The product will be replaced and shipped directly to you at no charge(more info20-148-296.0.18)
  • 1 year: $7.99
  • 2 year: $12.99
$115.96 ($28.99 each) . .
20-227-365-TS
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model OCZ3G1600LV6GK - Retail Item #: N82E16820227365 Return Policy: Limited Non-Refundable 30-Day Return Policy -$35.00 Instant
-$17.99 Saving
$10.00 Mail-in Rebate $139.99 $87.00 1
OCZ ATV 8GB Flash Drive (USB2.0 Portable) Model OCZUSBATV8G - Retail Item #: N82E16820227262 Return Policy: Limited Non-Refundable 30-Day Return Policy -$8.00 Instant
$25.99 $17.99 . .
13-128-375-TS
GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard - Retail Item #: N82E16813128375 Return Policy: Limited Non-Refundable 30-Day Return Policy Protect Your Investment (expand for options13-128-375|hide options13-128-375)
Service Net Replacement Extended Warranty Plan The product will be replaced and shipped directly to you at no charge(more info13-128-375.0.18)
  • 1 year: $19.99
  • 2 year: $35.99
-$10.00 Instant
$15.00 Mail-in Rebate $209.99 $199.99 . .
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail Item #: N82E16819115202 Return Policy: Processors (CPUs) Return Policy Protect Your Investment (expand for options19-115-202S1257|hide options19-115-202S1257)
Service Net Replacement Extended Warranty Plan The product will be replaced and shipped directly to you at no charge(more info19-115-202.0.18)
  • 1 year: $29.99
  • 2 year: $49.99
-$49.99 Saving
$279.99 $230.00 1
Tom Clancy's HAWX – OEM PC Game, Gift with Intel Purchase - OEM Item #: N82E16800992039 Return Policy: Standard Return Policy $49.99 . .
Microsoft Windows Vista Home Basic SP1 64-bit for System Builders - OEM Item #: N82E16832116483 Return Policy: Software Return Policy $89.99
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
you get a free 8gb flash drive, and a video game too with all that :-)
two diff memory options on there, if you want the flashing LED's get the crucial balistix, if not, get the OCZ Golds... both are decent. I have the balistix. lovem...
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
Grand Total:$1,279.90
and that is SHIPPED.
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
iTragedy;1026884 [B said:
Smarteyeball:[/b] How about this card?: Card
For decent performance in the ATI range, you'd best be looking at a 4850 or above. I would actually recommend the 4870 512mb over that card because even though that 4650 does have 1GB, the performance difference between a 4650 and 4870 is quite significant and any benefit of the 4650 having 1GB is negated by the lower clock speed :(
Newegg.com - XFX HD-487A-ZDFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards
Newegg.com - XFX HD-489A-ZDFC Radeon HD 4890 1GB 256-bit DDR5 PCI Express 2.0 x16 HDCP Ready Video Card - Desktop Graphics / Video Cards
These two are great performers, but do cost quite a bit more. Essentially clock speed is more important than VRAM. But if you can afford both, even better :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Hmm, for the meantime, I cannot afford that card.
Maybe later when I rack up some more money I will get it. Definitely.
lol ive been trying to help you past 2 pages, what is your price range??????
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
Sorry, when I posted that I only had enough time to reply to one post, and to yours It would take me a while xD
My price range is about 1000-1100 or so.
Some necessities: 1 TB Hard drive, 1 GB Graphics (600 MHz), DDR2 240 pin Ram (8GB), and a cd drive that has lightscribe and can burn BluRay.
Deal is, I can't spend a lot on a processor, so I decided to go with a combo with that motherboard and the AMD Processor.
Intel i7 is too expensive, and if I dish out for it, I won't be able to afford some things.
+ I will get the 2 LED Fans, Catholde Kit, PC Case, & a multifunction panel.
Also, as I understand it - (Being a first timer)
Once I hook up all my software to the motherboard and beyond, (Fans, keyboard, etc) the CD Drive should work, I should put the OS Install CD in, boot it up, Install OS, and then install drivers from CD's?
I can build you a Intel i7 setup for $1200 with a better video card, and a 300 GB Velociraptor... a 1TB drive i think would be cheaper so if you want thats fine... let me know i will email you the list and you can buy it :)
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
