A problem with Highlight newly installed programs
simoiu
Hey. I have Vista Ultimate x64 and i have a problem. If you look in the picture you see all programs in yellow box. I go to the programs in yellow box, i click them and it should dissapear but it doesn't. And the new program that i install aren't in yellow box. What should i do? I think Brink know ....
Thats not a problem. Eventually the highlight will go away. If it bothers you though, you can turn the highlight feature off.
right click taskbar>Properties>Start menu>Customize>uncheck box, click ok.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
Yes thanks but i want to have this highlight but this error to dissapear
What error? It is normal. Sometimes when I install new programs, It will stay highlighted for days.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
You don't understand. The problem is when i install new programs they aren't highlighted only 3 programs and normally whne i click the highlight must dissapear no? But it doesn't and this error is when i install the windows 2 weeks or later ....
It doesnt always work that way. I have had newly installed program folders stay highlighted even after I clicked on them. Eventually It will stop highlighting the new program.
Now if you have an issue where after weeks the highlighted folder is still highlighted, or new installs do not highlight at all its possible you may have corrupted the registry.
Follow the step above to turn off, then turn highlight back on, or look here.
1) Start the Windows Registry Editor by typing “regedit” in the Start -> Search box and press Enter . Click on continue if you see user Account Control dialogue box.
2) In the Windows Registry Editor, locate the key called:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
This can be done by clicking on the + sign near each item as mentioned above and select Advanced key
3) In the right-hand pane, look for the value called “Start_NotifyNewApps”.
4) If the value does not exist, then right click on the right pane and select New and then click DWORD (32-bit) Value. Then type “Start_NotifyNewApps” (without the quote) as the name of the new DWORD Value, and press Enter.
5) Right-click the “Start_NotifyNewApps”, and in the popup menu select Modify…
6) Change the Value data to a zero (0), and click OK.
7) Now close the Registry Editor.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
