Card is installed and works fine in my Vista Ultimate x64 system. 4GB RAM. Primary drive is SATA connected to on-board. Storage drives are to be connected to controller card. System boots fine as long as drives aren't connected to card. Once drives connected, system sits at boot-up splash screen w/ knight rider status bar. Never boots.
Any ideas would be appreciated.
The reason it wont or boot off your SATA drive when you connect it, is because it is not a SATA controller. It is a controller for IDE drives.
For VT6410, which is an
IDE RAID controller, use ATA HDDs (not SATA)-or dont use this controller. Evidently you have a onboard SATA controller otherwise your SATA HDD would not load (unless switched to IDE mode)
http://www.viaarena.com/default.aspx?PageID=5&ArticleID=54
Many SATA controllers offer selectable modes of operation: legacy
Parallel ATA, standard AHCI-mode, or vendor-specific
RAID. Intel recommends choosing RAID mode on their
motherboards (which also enables AHCI) rather than the plain AHCI/SATA mode for maximum flexibility, due to the issues caused when the mode is switched once an operating system has already been installed.
[2] Legacy-mode is a software backward-compatibility mechanism intended to allow the SATA-controller to run in legacy operating-systems which are not SATA-aware.
http://en.wikipedia.org/wiki/Advanced_Host_Controller_Interface
Unless you switched your HDD in the BIOS from ACHI to IDE, I dont know why you would be using a IDE storage controller for a SATA drive.
I would check your device manager for the storage controller, It should be a SCSI (if it wasnt Windows would not see your drive, and thus not load it). When you tell it to use a IDE (ATA) controller It will look for PATA/ATA Hard drives, then will not find it, and will not load the drive- thus Windows does not load.
This is the version 5.80c for Vista x64 SATA storage controller for Discrete Serial ATA RAID controllers VT6420/1 (
VT6420 VT6421 )
VT6410 IDE RAID controller (
VT6410 )
http://www.viaarena.com/default.aspx?PageID=420&OSID=37&CatID=3000&SubCatID=117
