pdsnickles
Man, this is a mess!
I don't know where to start... At the beginning I guess... which seems like ages ago but it was only a few hours ago...
Okay, I wanted to shrink my 650gig C drive down to 85 or so. I read a tutorial on the net about how to do it and they said that you could do it by defragging with Perfect Disk, defragging the System Files with it, and then performing a few other steps which would allow you to shrink C to a lot smaller than the 350 gigs it was originally allowing me to do.
The steps were to turn off hibernation and delete the files, turn off system restore and delete files, and turn off the page file.
Then perform a defrag and then a system file defrag on boot up, then shrink.
I did this and then repeated the "rinse, lather, repeat" about 3 times to get my C drive down to 85 gigs and leave the biggest part of my 750gig HD for archiving only. Seemed like a good idea... at the time...
So the Shrink process went well. Each time I did a System File defrag with Perfect Disk, figuring that each time the drive shrunk, it could move the MFT file a little closer in thus allowing for more shrinkability. It seemed to work.
After I got C drive down to 85 gigs, I immediately restarted and re-stored my page file settings to "let Vista manage" it, and re-started System Restore and created a new restore point.
But when I re-set the page file I got the message: "Another page file exists, do you want to replace it with this one?" I said, sure, why not? I have a feeling I should have said no. But I moved on...
NOW I had a 600 gig unallocated section that I needed to format to NTFS. But Vista Disk Mgmt said I could not format it because I already had the limit of 4 partitions:
1. The EISA drive
2. OS C drive
3. Recovery Drive D - came with the Dell
4. Rip Process Download R - I created with Paragon Partition the other day
then
5. Unallocated - the partition I just created by shrinking C drive with Vista
I knew there was a limit on the number of partitions you could have, which is why I fired up Paragon Disc Manager, which is supposed to do this kind of thing, right?
Well, when I tried to use Paragon via Windows it would not work and wanted me to put in the Recovery Disk to do it. So I did. But I don't know if my recovery drive went bad since I used it a few days ago, or what, but I could not get it to boot. I got a message saying the DVD drive was not accessible. I had used it earlier to look at the disk and it was working fine.
Now I began to wonder if all the changes I made: defragging sys files, deletion of page file, hibernation file, etc. may have caused this problem...?
I tried re-inserting the disc and I ended up with a black screen with only the cursor flashing in the top right. I could not go back, I could not go forward, I could not pass Go nor collect $200. I was stuck like a fly on flypaper.
I did a hard shut down and then restarted and tried again. Again I could not access the disc and again I had to do a hard shut down, and this time I let it boot back to Windows.
Once back to Windows, I tried to look at the contents of the Paragon Recovery CD and when I did, my computer was very slow to respond. It froze up and I got a message that said Windows Explorer was not responding. I closed out of the window and tried again. Same thing: Error pop-up window: "Windows Explorer is not responding".
I closed out and decided to try the Windows version of Paragon Manager again. It should be able to just format a drive in Windows, no?
So I opened it up and found that as before, the Format option was greyed out for that partition. So I got the idea, "Maybe I can "create a partition" using that unformatted area but instead of creating a partition within it, I'll just create it as an entire partition". So I tried that but when I got to the final step I got a pop-up error - actually 2 at the same time:
One said "The restart that has been requested cannot be performed under Vista 64-bit. Please use Recovery CD." And at the same time (See jpg) I got the message, "Virtual Disk Service stopped working and was closed. A problem caused the app. to stop working correctly."
So I restarted and put in my 2nd copy of Recovery CD and gave it one more shot.
This time it booted into the cd and I was able to get to the Paragon Disc Manager interface.
I tried the same thing as above: to create a partition over the unformatted partition, and this time it worked. Finally! But at what cost??
I booted back into Vista and Vista immediately gave me a pop-up window showing me these 3 errors: the 2 Explorer errors above and a new one:
"IDT PC Audio stopped working". And, sure enough, I had no audio.
But now, magically, my audio is back working and I have had no further errors.
But I have a feeling that I will... I think I must have screwed things up. In my defense I read this procedure about the page file and restore points deletion and system file defrag etc. in several seemingly respectable tech sites on the net. In fact, Perfect Disk itself recommends doing the defrags and then shrinking. They didn't say it was okay to do it 3 times in a row but then they didn't say not to, either. Perfect disk does defrag the page file but they did not recommend deleting it, I got that from a couple different "how to shrink" web pages. But the sources said that it was fine to delete it, it would come back as soon as I re-set it in System.
So here are my error messages that I copied from Windows re Windows Explorer freezing up and the audio error:
"--1st EXPLORER PROBLEM--
Product
Windows Explorer
Problem
Stopped responding and was closed
Date
4/18/2009 12:04 AM
Status
Not Reported
Description
A problem caused this program to stop interacting with Windows.
Problem signature
Problem Event Name: AppTermFailureEvent
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Files that help describe the problem
Version.txt
--2nd EXPLORER PROBLEM--
Product
Windows Explorer
Problem
Date
4/18/2009 12:07 AM
Status
Not Reported
Description
Problem signature
Locale ID: 1033
Version.txt
--AUDIO PROBLEM--
Product
IDT PC Audio
Problem
Stopped working
Date
4/18/2009 12:36 AM
Status
Not Reported
Problem signature
Problem Event Name: APPCRASH
Application Name: STacSV64.exe
Application Version: 1.0.6017.1
Application Timestamp: 4835e75e
Fault Module Name: msvcrt.dll
Fault Module Version: 7.0.6001.18000
Fault Module Timestamp: 4791ad6b
Exception Code: c0000005
Exception Offset: 0000000000003237
Locale ID: 1033
Additional Information 1: 39b1
Additional Information 2: cd356529eaae0727bbb34e304627cf80
Additional Information 3: db08
Additional Information 4: fb967711e114209fef336ac52fb63c44
Version.txt
AppCompat.txt
memory.hdmp
minidump.mdmp"
Anyone have any ideas? What do I need to do to get back a properly functioning Vista? How badly did I screw up? And what is "Virtual Disk Service" and why did it stop working?
Thanks for any light you can shed on this mess! And sorry for the super-long post but believe me, it's much better reading it than living it!
Update: Okay I looked at my Windows>System logs and it appears that the attached jpg shows that it was simply a bad compact disc, so that error was unrelated to anything else. And I'm guessing that because the computer was trying so hard to read the bad cd, that's why it froze up on the black screen with just a cursor.
Specs:
Windows Home Premium 64bit
Dell XPS 430
750 gig SATA hard drive
Intel Core 2 Quad Q8300 Processor
ATI Radeon HD 3650
1. The EISA drive
2. OS C drive
then
Product
Windows Explorer
Problem
Date
4/18/2009 12:04 AM
Status
Not Reported
Description
Problem signature
Locale ID: 1033
Version.txt
Product
Windows Explorer
Problem
Date
4/18/2009 12:07 AM
Status
Not Reported
Description
Problem signature
Locale ID: 1033
Version.txt
--AUDIO PROBLEM--
Product
IDT PC Audio
Problem
Stopped working
Date
4/18/2009 12:36 AM
Status
Not Reported
Problem signature
Locale ID: 1033
Version.txt
AppCompat.txt
memory.hdmp
minidump.mdmp"
Specs:
Dell XPS 430
ATI Radeon HD 3650
- DELL XPS 430
- Intel Core™2 Q8200 Quad-Core (4MB L2 cache,2.33GHz,133
- 7200RPM, SATA 3.0Gb/s, 16MB Cache
- 6GB Dual Channel DDR3 SDRAM at 1066MHz - 4 DIMMs
- ATI Radeon HD3650 256MB Graphics (Integrated)
- Integrated 7.1 Audio (IDT/Sigmatel 6.10.0.6017)
- Dell -1901FP Flat Panel LCD Color Monitor
- 1024 x 768 32 bit
- 750 gig SATA 7200 C drive External Seagate 160gig " Western Book 160 gig " Hitachi 250 gig ALL USB except C drive
- Microsoft Intellimouse Trackball - (best design ever made!)
- Logitech ITough Multimedia
- ATT Yahoo Elite DSL 4797kbps down, 624kbps up
