First time builder stuck!! Please help!!
eidsonjm
Ok, first off specs are in my sig....refer to them first plz.
Every peice of hardware is brand new and there is nothing saved in my hard drive right now.
I am doing a clean install of windows 64 home premium edition, basically when i get to the screen that asks me where i want to install windows...there is no drive for me to choose. My Hard drive is SATA and it is detected in BIOS in the IDE channel 0 Master slot. I have tried other SATA cables and I have tried other SATA slots. I have tried AHCI option in BIOS. I have tried runnin in Native Mode as well as Legacy IDE mode.
I got my drivers from GIGABYTE - Upgrade Your Life
I click the correct model number and at the next page on the bottom it asks for the type of OS you have...I select windows 64 obviously. I then save the drivers to my USB drive. I extract the files and switch my USB drive over to the new comp. when i get to the screen that asks me where i want to install windows, there is an option to load drivers. However, once i load the drivers the only way they can be selected is if I un-check the box "HIDE DRIVERS THAT ARE NOT COMPATIBLE WITH HARDWARE ON THIS COMPUTER." Now, one would think that i have incompatible drivers...but i'm getting them directly from the mobo website.
If there are any suggestions or anything at all that i have missed please tell me. I hope i provided enough info, if not then just ask...i will be refreshing all day to see if someone has a solution for me. Thanks in advance.
p.s. remember this is my first tim,e building, so, if it is a stupid fix don't make fun ;)
    Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Pr
    GIGABYTE GA-EX58-UD5 LGA 1366 Intel X58 ATX Intel Motherboa
    OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memo
    EVGA 017-P3-1294-AR GeForce GTX 295 1792MB 896 Bit GDDR3 PC
    Dual SAMSUNG ToC T220 Rose-Black 22" 2ms GTG Widescreen LCD Monitor
    SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
    CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire
    Thermaltake Armor Series VA8003BWS Black Full Tower Case w/
    Logitech G5
    Logitech G15 USB Wired Standard Gaming Keyboard
    Roadrunner with power boost
my sig isnt working atm....standby i'll get you the specs.
    Logitech G5
Have you checked your BIOS settings?
Is it set at the right configuration for the type of drive you have (ide or sata).
    Acer Aspire 5920gmi notebook
    NVIDIA GeForce 8600M GS
    Realtek
    crawl
yeah i've tried all sorts of different settings just to be sure. I've tried AHCI and RAID. I've tried the normal SATA/IDE settings...
edit: specs are up
edit #2: Yes, i have F6 BIOS version....i think when i updated i either already had F6 or when u update there is no actual change in the way it looks because it looks the exact same and same exact option as pre-update...
    Logitech G5
yes i've set the partition and it's completely formatted.
    Logitech G5
May sound dumb but... have you made sure you HDD is connected to SATA Port 1 on the motherboard?
Edit i re read ur post and saw the part about the slots sorry
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
it's connect to IDE Channel 0 Master farthest right, lower slot for the SATA slots on my mobo
    Logitech G5
Can you explain so iv got it rite.... you only have 1 HDD?
And you have it connected via IDE and Sata?
Sorry but i might just be getting a little confused here
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
correct..i only have 1 HD, which is why i'm not connect to any of the RAID slots.
I'm connect to the first SATA slot in my mobo. In BIOS it reads as Channel 0 Master.
    Logitech G5
OK well that sounds normal about it displaying in Bios as channel 0
Now the other thing is what cables do you have connected since you have mentioned IDE and SATA
If im getting you right your saying that you have 3 cables connected to your HDD.. If this is correct then this is where you problem lies
You should only have 1x sata power cable via your PSU and 1x Sata cable(usually red) connected from sata port 1 to the HDD
Now if im thinking you have also connected and IDE cable(Long/Wide strip connector) then this needs to be removed as its not needed
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
No, i only have the SATA cable and the PSU cable connected. Only reason i mentioned IDE is because in BIOS i have the SATA/IDE device enabled and the Hard drive is being detected in IDE Channel 0 Master.
I do have the option for SATA Port 0-3 work as Native IDE Mode or Legacy IDE Mode. It has to be one or the other, i can't disable both options. Which one do you recomend? I have tried both though already.
Edit: Also there is Onboard SATA/IDE Ctrl Mode. I can either choose for my SATA ports to work as IDE mode or AHCI mode. I have tried both of these also. Which do you recomend?
    Logitech G5
If you have tried both then disabling any will be of no help... however in your bios usually on the main page you will have the likes load default setting save and exit ect
if like my board And most current Highbrid board you should have a Load Fail Safe settings.. this should disable any unessential bios settings and thus should allow for correct Auto configeration which in turn should allow you to load windows setup and install the drive... if this does not help you then i can be of no further assitance
Unless this fault lise within the Ram issue in what case you will need to remove all sticks to one and replace after installation :confused:
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
i only have 1 stick installed in slot 2 atm i wont be installing moire until i have my OS up and runnin
edit: slot 1 meant
    Logitech G5
Is there an option between IDE and IDE enhanced mode?
However, since it's a fresh install and you have no other IDE devices etc, AHCI is what you want.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
no enhanced IDE option...and since i've tried going the AHCI route already i dunno if that will help me.
    Logitech G5
i just loaded fail-safe option and re-booted. I get stuck at "verifying DMI pool data......................"
then it has about 9 special/weird characters on the next line and it just hangs....
    Logitech G5
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Antec 900
meh...i just switched the boot order to CDROM> hard drive> then blank
it booted up fine and it still didn't fix my problem :(
    Logitech G5
Just to clear it up, you don't need to worry about loading any drivers for your hard drive, so it won't be causing any problems this.
Unless I've missed something as well, have you tried connecting the hard drive to another SATA port? It doesn't "have" to be connected to the first SATA port.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
yeah i've tried them all actually there are 6 total SATA ports and 4 total sata/RAID ports.
edit: also i was loading the SATA drivers into the motherboard...not drivers for hard drive.
    Logitech G5
