Hi, Brink et al.
I experience a lot of warping in an online game that I play now and then, Aces High II. My system has plenty of RAM (4GB) and a good mobile GPU; so, I know the problem is caused by something else.
I have disabled all unnecessary services, per blackviper.com.
The tech guy at the game company said that I need to "disable all power management" because it is the main source of warping online. Hmmm...ok. I'm willing to give it a try.
I searched the forums; this thread is the closest thing I found about disabling all power management in Vista. Didn't really give me what I'm looking for.
I was surprised that there isn't a Service in Administrative Tools > Services that I can just disable.
Any idea how I might disable all power management in Vista Home Premium -- at least, temporarily while I see if it makes a difference?
Thank you!!!
My system, in case it matters:
Gateway P-6860Fx laptop
Processor: Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz (2 CPUs), ~1.8GHz
Memory: 4094MB RAM
Page File: 1110MB used, 7251MB available
Card name: NVIDIA GeForce 8800M GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800M GTS
Display Memory: 2266 MB
Dedicated Memory: 475 MB
Shared Memory: 1791 MB
Thank you!!!
Memory: 4094MB RAM
- Gateway P-6860fx
- Intel Core2 Duo 1.83GHz
- 4 GB
- NVIDIA GeForce 8800M GTS
- Cable
