System Restore Point - how long
thelowester
How long should a sytem restore take on vista 64?
All it says is - System Restore is initialising
I am restoring from yesterdays fresh install (one of many fresh installs).
I have to add that v64 is perhaps the worst, most unstable and unpredictable OS I have ever used, worse than Win Me.
Hello theLowester,
It normally doesn't take to long (ex: 15 mins or so), but it can depend on how much you have installed on your computer as well.
The only thing I can say about your problems with x64 is to make sure that you have the latest 64-bit drivers installed for all of your devices, motherboard chipset, and BIOS.
