Vista System Restore initializing problem
m4loo
I am experience problems with a system restore that I started some 11 hours ago on a one and half year old Fujitsu Siemens AMILO LI 1718 laptop. The problem started a few days ago when it took an “age” to boot up and everything seemed very slow. I managed to run Antivirus and Malware software to see if there were any virus’ but none were found, hence the attempt to restore.
All I can see at present is “Please wait … system restore is initializing” and the circular egg time is continually spinning. One keyboard light remains on whilst another flashes intermittently.
The OS is x32 bit Vista Home Premium, Dual Core, RAM is 2gb, memory 80gb and 160 Mhz.
My question is: do I leave it for another xx hours or should I turn it off and reboot.
    Fujitsu Siemens Amilo Li1718
i would reboot with the windows cd and try restoring that way. the setup process should have a repair option. hopefully you have a couple of restore points to choose from.
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
