Solved Help- Print job won't delete
GratefulDean
:sa: I have a print job at the top of a list of others that is frozen. It's an 11 page document that says it is a 21 page. I have tried to delete it to no avail and since have deleted the other jobs and restarted the computer only to have it reprint the first half, as far as it got before, then stopped. Where else can I go in the computer to delete this. I have alot of work yet to do and would prefer to not have to uninstal and reinstal the printer.
Thanks guys and gals,
Dean
PS I had set the printer HPOfficejet 6480 to print both sides which may be why it printed only half the pages? No matter the issue I believe is in the software.
    HP Pavillion dv3510nr
    Processor Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz, 2
    4G
    NVIDIA GeForce 9300M GS
    SynchMaster2300sw
    1280x800x60hz
    WD MyBookHome 1T external
    Fast yo
I went and restarted the computer again and then hustled to the printers page and deleted all jobs before it could start printing. Seems to have worked. But I learned about Spools, which I had never heard of before...
SOLVED
Dean
    4G
    SynchMaster2300sw
    1280x800x60hz
    Fast yo
Hi GratefulDean,
This is for your future reference. if you want to delete a print job with out restarting the computer, type services in start-search > restart "print spooler" service. you are done.
Start new job :)
hope this helps.
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    19" Viewsonic and Sony 26" S Series TV
    1920x1080
    Sata (1 TB) and IDE (350GB)
    Optical (Wireless)
    Multimedia (Wireless)
    2MB
Hi GratefulDean,
Start new job :)
hope this helps.
Nice, thank you,
Dean
    4G
    SynchMaster2300sw
    1280x800x60hz
    Fast yo
