Solved need help, no signal to monitor at startup
johnz
When I shut down my computer I accidently must have selected lock or logout, now when I turn on computer there is no signal to monitor. This happened once before but don't remember what I pressed to get it back. I need help:(
Hi johnz,
Welcome to the vista forum.
Did you try unplug the power cable from Tower and hold the power button for 2-3 mins and try turn on the computer ???
if not, try it and let us know. it may be due to static power.
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    19" Viewsonic and Sony 26" S Series TV
    1920x1080
    Sata (1 TB) and IDE (350GB)
    Optical (Wireless)
    Multimedia (Wireless)
    2MB
Thanks for the response. I was turning computer on and off and did not correct problem but when I unplugged power cable or short time then turned back on monitor was displaying for computer that had been locked. How can I prevent this from happening in future? Is there a setting?
Good to hear that.
There are some steps to Avoid Static Damage to Your PC.
Some of them are:
Check your AC wiring
Use a wrist strap
Use additional antistatic components
do you know that Google is your friend :)
Good luck.
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    1920x1080
    Optical (Wireless)
    2MB
