What makes my system not 64bit worthy?
maspunk420
i recently bought the upgrade disk for my comp...
previously i was running xp home edition but thought my comp could use something with 32 extra bits....
when i put the 64bit edition of vista in it tells me that the disk is unreadable....
nForce 680i SLI motherboard
2x2 gig OCZ SLI ram
500 gig maxtor hard drive
700W OCZ power supply
XFX 9800 GTX+ graphics card
intell core 2 quad 2.4GHz
any other info i'm sure i can tell you
    MUT
    intel core 2 quad 2.4MHz
    EVGA nForce 680i SLI
    4x2GB OCZ SLI
    9800 GTX+ x.5
    HP w1907
    Maxtor 500GB
    OCZ 700W
    Cooler Master Centuriun
    120mm intake, 120mm exahust
    Logitech Trackman Wheel
    Microsoft Digital Media 3000
    Garbage
Don't quote me on this but I have heard that upgrading from XP to Vista is not a good thing, it is best to do a clean installation.
Now, it is also said that, for some reason, Vista doesn't like it when you install with 4GB's of Ram (again... hearsay).
Your rig is better than mine and I am Dual Booting with XP 32 + Vista x64 so I don't see why you can't.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
i dont think you can use the 64 bit upgrade disk on a 32 bit O/S already installed
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
hey thanks i'll try to do a clean install with my extra ram in and hopefully that will help
    MUT
    4x2GB OCZ SLI
    9800 GTX+ x.5
    HP w1907
    Maxtor 500GB
    OCZ 700W
    Garbage
You can't, you would have to do a clean install. It would have to be 32 to 32 or 64 to 64 bit...
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
And to do that with an upgrade disk,
http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html
Also,
Only with certain chipsets mainly, and the workaround was to pull 2 GB, install, and add the other 2 GB back (for some a bios update fixed it as well). There is/was a patch/hotfix for it for it as well,
Error message when you try to install Windows Vista on a computer that uses more than 3 GB of RAM: "STOP 0x0000000A"
which is included in SP1. If maspunk420's x64 disk has SP1 on it, he shouldn't have any problems.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
clean install worked everything is perfect thanks guys
    MUT
    4x2GB OCZ SLI
    9800 GTX+ x.5
    HP w1907
    Maxtor 500GB
    OCZ 700W
    Garbage
