So I go my new motherboard today (eVGA nForce 780i SLI FTW Edition) and just got it installed. I go to power up my system and everything seems alright... However upon closer inspection I notice that all of the things on my PC that "light up", such as my fans and cold cathode tube, happen to be "flickering" at a fairly high interval. It was almost like seeing a florescent tube flicker or and extremely fast strobe light. It also sounded like all of my fans were cutting in and out at the same interval... Sounds like some kind of power issue.
The motherboards onboard indicator was outputting the "FF" code, which means "Boot" in the manual... Apparently this is a good thing, and simply means that the system is working. However I get absolutely no graphics signal output.
I assume there's a bad connection somewhere, but I've checked and rechecked all of my connections. Everything is fine... Has anyone seen anything like this before?
- Acropolis
- Intel Core i7-6800k @ 4.0 GHz
- ASUS X99-M WS
- 32GB Corsair Vengeance 2x16GB
- ASUS GeForce GTX 1080 STRIX
- ASUS ROG Swift PG278Q
- 2560x1440
- 2x 256GB Samsung 850 Pro (RAID 0) 1x 500GB Samsung 850 Evo 2x Western Digital RED 4TB (RAID 1) 50TB File Server (Multiple RAID 6)
- PSU
- Corsair AX1200i
- Case
- Corsair Air 240
- Logitech G502
- Razer Blackwidow X Chroma
- 250Mbps Down | 15 Mbps Up
