Vista freeze must hard reboot to fix, help
gaggaz
i have a Asus M51vr-ap046c with Vista Business Sp1 and some updates, i have updated the intel wifi 5100 driver, to fix some issues but i have still one problem:
Sometimes Vista will freeze, and i must hard reboot to recover, no bsod, or event viewer entries except it shutdown unexpectedly.
eg: monday: was on for 3 hours, going into sleep twice, no issues
Friday: Froze, was watching a .flv (5 meg) file from hdd, sound went into repeat.
What was running:msn,thunderbird,avast,asus utilities, was fast until freeze.
Because the way it freezes i can lose work, i don't wont to lose work!
A mate with the same laptop and configuration like mine and doesn't have this issue, only a few differences, he has more things installed and running in memory and a netgear router wrn3500, i got a Dlink dir 615.
If there anymore details plz ask, going to work sat 11-4 pm
i never really get program crash's, only this problem
Thanks,
Gaggaz
    Asus M51vr ap046c
    intel p8600
    some intel chipset (in asus laptop)
    4gb 2*2gb
    ATI 3470
    inbuilt 'realtek' HD
    1280*800
    320gb WD
    fingerprint wifi n bluetooth firewire tv tuner dvd burner
There are already al lot of thread about Vista hanging "without" reasons. Just use the search option. Keep knowledge bundled! Look into your logfiles (admin tools) and see if you have the same issues. The worst of all is often... nothing to do about it if MS keeps ignoring the problems!:
http://www.vistax64.com/vista-general/79816-vista-freezes-randomly.html
http://www.vistax64.com/general-discussion/198568-error-event-viewer.html
http://www.vistax64.com/general-discussion/197776-desktop-freezes-i-must-restart-computer.html
http://www.vistax64.com/vista-installation-setup/98907-vista-locks-up-randomly.html
http://www.vistax64.com/general-discussion/204146-vista-randomly-hangs.html
    Intel Core 2 Duo E8600
    Asus Rampage Extreme
    OCZ 4 GB DDR3-1066 Kit
    Club 3D HD4870 X2 2GB
    Creative X-Fi Titanium Fatal1ty Champion Series
    Samsung T200
    2x 500GB Western Digital VelociRaptor
    Cooler Master COSMOS S
    Standard cooling
    Razer 3G
    Logitech G15 (orange)
    20MB
i have looked into these and yes i have these two same errors, not as much freeze's, i did update the wifi, that helped a bit , but i have down every kind of hardware test and even the shop did too, no issues.
But why doesn't this happen to my friends , they have vista and weirdly my friend who has the same laptop and configuration....
so i'm still looking around...
but i noticed some asus m51vr users on forums have similar problems and like me, it doesn't happen much when i'm plugged into AC.
But i can make it happen when 'allway sync' is transferring large files, but it wont happen through windows file sharing.
mmm,
thanks,
Gaggaz
    Asus M51vr ap046c
    intel p8600
    4gb 2*2gb
    ATI 3470
    1280*800
    320gb WD
Don't bother to try to find a solution... there is nothing logical about this problem. For 4 months I had many freezes (very day, sometimes multiple), now "suddenly" the last freeze was 2 weeks ago (huh?) ... I didnt reinstalled vista so... donno what happened... Maybe it was one of the drivers (sound, videocard).... *crossing his fingers*
By the way: I can only force it to freeze it for exemple using Smartftp and upload stuff... Downloading is no problem. All othe situations (sound and video) no problem anymore.
    Samsung T200
    Standard cooling
    Razer 3G
    20MB
