GLOBES New Member Feb 1, 2009 #1 I reformatted my computer by myself and Before I had 160 gb and now I only have 40 gb ! Can someone tell me were is my lost memory?? THANKS ! My Computer System One
M mansrm81 Vista Guru Feb 1, 2009 #2 Re: I need help ! Did you format the drive in NTFS format. My Computer System One Manufacturer/Model HP Compaq Presario/SR5113WM CPU AMD Athlon 64 X2 3600+ 1.9Ghz Motherboard Asus M2N68-LA Memory PNY Optima Memory DDR2 2GB 2x1 kit Graphics card(s) PNY Nvidia 8400 GS 256MB Sound Card On board RealTek Monitor(s) Displays Acer X163W LCD Screen Resolution 1366x768 Hard Drives Western Digital 160 GB SATA 3G (3.0Gb/sec) 7200 rpm Western Digital 160 GB IDE PSU Dynex 400w Case Nothin Special Cooling Stock Mouse Wireless Logitech LX7 Keyboard Standard 102 key with volume and sleep buttons Internet Speed Comcrap 10mb cable Other Info Insignia 2.1 speakers, wireless Xbox 360 controller w/plug n play charger, Belkin wireless G + mimo usb network adapter.
GLOBES New Member Feb 1, 2009 #3 Re: I need help ! I dunno I just reformmated with my cd and just click reformat :S Please were did my memory went? Give me stuff I can try so I can maybe ge tit back? Thanks ! My Computer System One
H hawk5 New Member Feb 1, 2009 #4 Re: I need help ! in how many partitions you divided you 160 GB? I meant that you formated your whole hard drive or just one partition? My Computer System One
GLOBES New Member Feb 1, 2009 #5 Re: I need help ! Like I said I have totally NO IDEA ! Thats the problem I just refformated and I dont remember nothing:huh: My Computer System One
KrossX Member Feb 1, 2009 #6 Re: I need help ! During installation you should see the disc(s) and the partition(s) it has. Did you only see one disc with one partition? Or more simple... did you see just one drive? (like Drive C and nothing more) Also, you didn't mess with RAID, did you? My Computer System One Other Info Windows 7 is love~~
Brink Staff member mvp Feb 1, 2009 #7 Hi Globes, Open Disk Management, and see what you have listed for your drives (disks) and partitions, and please let us know what you see. Control Panel, Administrative Tools, Computer Management, Disk Management in left pane. We'll see what we can do to help. My Computers System One System Two Operating System Windows 10 Pro 64-bit Manufacturer/Model Custom CPU Intel i7-8700K 5 GHz Motherboard ASUS ROG Maximus XI Formula Z390 Memory 64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR) Graphics card(s) ASUS ROG-STRIX-GTX1080TI-O11G-GAMING Sound Card Integrated Digital Audio (S/PDIF) Monitor(s) Displays 2 x Samsung Odyssey G7 27" Screen Resolution 2560x1440 Hard Drives 1TB Samsung 990 PRO M.2, 4TB Samsung 990 PRO PRO M.2, 8TB WD MyCloudEX2Ultra NAS PSU Seasonic Prime Titanium 850W Case Thermaltake Core P3 Cooling Corsair Hydro H115i Mouse Logitech MX Master 3 Keyboard Logitech wireless K800 Internet Speed 1 Gb/s Download and 35 Mb/s Upload Other Info Logitech Z625 speaker system, Logitech BRIO 4K Pro webcam, HP Color LaserJet Pro MFP M477fdn, APC SMART-UPS RT 1000 XL - SURT1000XLI, Galaxy S23 Plus phone Operating System Windows 10 Pro Manufacturer/Model HP Envy Y0F94AV CPU i7-7500U @ 2.70 GHz Memory 16 GB DDR4-2133 Sound Card Conexant ISST Audio Monitor(s) Displays 17.3" UHD IPS touch Screen Resolution 3480 x 2160 Hard Drives 512 GB M.2 SSD
