Multi-monitor side bar issue.
goodBEan
Right now I am running a vista machine with 2 monitors one widescreen and my old one. I keep all my sidebar gadgets to the other monitor so I can monitor temps and system diagnostics. Today, my sidebar is on my main monitor and no mater what I do it won't go back to monitor-2, no mater what the setting is in the sidebar properties. What is going on here?
    MSI K9n2 SLI platnium
    AMD PHENOM x4
    k9n2 sli platinum
    4 gb
    nvidia gt 9800 1gb
    multi montior
    1024 by 768
    1tb sata WD
    cosair 660wat sli
    modified antec
    a bunch of fans
    logitech g5 2 button edition
    old junker
I got rid of a bad gadget, but I still have the problem
    AMD PHENOM x4
    k9n2 sli platinum
    4 gb
    nvidia gt 9800 1gb
    multi montior
    1024 by 768
    1tb sata WD
    cosair 660wat sli
    modified antec
    a bunch of fans
    old junker
Open up your setting and check to make sure the other monitor is still registered in there. Have you recently added or changed anything?
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
Both monitors have always been in there. Here is the odd part, while I was loading up some old games, it seamed to fix itself. I guess when one of the games switched to the resolution to my old monitor it knocked everything back to the way it was.
    AMD PHENOM x4
    k9n2 sli platinum
    4 gb
    nvidia gt 9800 1gb
    multi montior
    1024 by 768
    1tb sata WD
    cosair 660wat sli
    modified antec
    a bunch of fans
    old junker
Hmmm... Your pc seems to be an older model, so I dunno. Could be some weird error...
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
