ryen2324
Hey everybody,
I fixing a computer for a friend and i have just been stumped about it. It is a Gateway Laptop that has Vista. I know the major problem is that the computer will not start up when i hit the power button. It will turn on and you can hear the fans going but then it all stops and nothing happens. The screen stays blank and it doesnt even get to the Gateway start up screen. After awhile i just power it down by holding the power button. the weird thing is that sometimes it will start up just fine and get to windows explorer and you think that everything is fixed but then it will freeze up on you and you must power it down starting the start up problems up again. i have made it through a couple of virus scans and took all the viruses that it had on it and i thought that that would take care of it but it didnt. it also has the problems of some of the keys on the keyboard dont work anymore and the touchpad doesnt work at all. i keep trying to install the drivers for those again but it keeps freezing. any ideas??
Thanks
Thanks
- Toshiba Satellite A135-S4427
- Toshiba
- 120 GB hhd 1GB ram
- Integrated Intel GMA 950
- 15.4-inch TFT
