help dvd drive works but wont reed cd's
blazer108
well guys i'm at the end of my wits here i have lite on dvdrw drive that wont reed cd's but plays dvd's now i have removed in from my computer and tryed in 2 other computers and it reeds and writes anything fine but as soon an it is back in this computer with Vista Ultimate 32bit it wont reed cd's i have tryed all the driver things i even formatted my computer and it worked for a few weeks then back to the same thing i even pulled it and put in a cdrw but it would not reed so i tryed a dvd rom and it worked ireally dont get it i need some help is i have been looking all over and a lot of people have this happen to them but noone seems to know how to fix it
I just had to replace a drive here when at first it refused to even see dvd-rw disks in the drive. At first a new cable worked well for all disks until just lately hearing a grinding sound while trying to boot off of a live cd. New cable or drive? I tried both out here.
    Custom built desktops =2 Toshiba replace HP laptop
    AMD Phenom II X4 975 Deneb core 3.6ghz
    Gigabyte GA-790XTA-UD4
    Kingston Hyper X 1.5v DDR3 PC12800 1600mhz 16gb
    MSI Radeon HD 5750 1tb
    Creative X-Fi XtremeAudio PCIe
    Asus 19" HP 20" second lcd main HP 20" remote pc.
    1440x900, 1600x900 main - 1600x900 2nd desktop
    WD Black Edition 1tb Sata II -2 WD SAS "Heavy Duty" RE class 2tb - 2 External usb/eSata WD Black 1tb main -1 External usb only WD Green Power 1tb -1
    Corsair 750w 750TX main - Corsair 600w remote
    Antec 900-2 - SSD compatible eSata ports 2 - NZXT Vulcan 2nd
    Zalman CNPS9900A cpu, twin front 120s, top 200cm, rear 120
    MSI Interceptor D200
    AZIO Ilumminated keys gaming keyboard/volume control usb
    30mbps upgrade
Do you have any other cd ripping/burning tools installed - or any or the commercial apps. like Nero , etc?
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
With the cable replaced the next thought would be the connection on the board since the drive seems to work well on other systems. Have you tried a different drive on this one inplace of the problem drive?
If you see another drive run into the same problems since Windows has been reinstalled ruling out an OS problem of some type you may be seeing a cold solder point on the connector itself. But if another works normal leave that one in and put the problem drive on a system you know it works on.
    30mbps upgrade
