Ok im running vista (Duh?) and i need to put up a wamp server, but i can't cause this NT Kernal thingy is taking port 80 and i can't figure out how to change the Wamp port from 80 to something else.
How i came to know its this, i used run, Cmd, netstat -oa, Look for port 80 and checked what the PID was, started task manager, showed the PID and said this was taking the port.
So my questions are, what does Nt kernal do?
And if its not an important program how can i disable it?
