Vists Home premium 32 bit is not supporting Eyeball
daviddessouza
can someone help me my eyeball is not working with vista.
configaration is ----
HP Pavilion dv6700
intel core2 duo CPU T5750 @ 2.00 GHZ.
RAM 3070 MB.
32- Bit OS
Hello David, and welcome to Vista Forums.
Is this what you are referring to below? If so, then you might check the items listed there to see if they may help.
Eyeball Chat - Help : Troubleshooting
Hi David,
I'm not sure whether it is even supported on Vista. Notice that the requirements don't mention Vista and that the date at the bottom is 2005. Vista, as you should know, was released to the public in early 2007.
attachment.php
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
True David, but a lot of what applies to XP may also apply to Vista, if it supports Vista.
It does seem to be a pretty old program. You might see if running the program in Compatibility Mode with Windows XP selected may allow it to run in Vista.
