Primary Monitor will not always come out of sleep mode.
JesterMagic
My Gateweay with a 8800GT, Vista 32 bit and with dual 21" dell monitors sometimes after sleep the primary monitor will not wake up (the other monitor well) or sometimes the screen has a bit of graphical noise. If I reset the resolution all is ok (until the next time). This started about 2 months ago. I know it is not the monitors because I switched them.
Now my new Acer with an 9800 GT, Vista 64bit with 2 Samsung 24" monitors is doing the exact same thing. I highly doubt I have 2 problem video cards so it must be a driver issue.
Any ideas, I now have the latest Nvidia drivers installed...
Hello JesterMagic, welcome to Vista forums!
Have you tried to roll back to an earlier driver?
Keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Since it is on two different machines with (presumably) different hardware, the only thing that is in common is the user - you.
I'd take a good look at what you are doing on the machines and what programs you have installed - I am betting that it is likely either your environment or else it is your programs causing this.
I have been using dual monitors for going on 5 years now and never had an issue where a monitor would not wake up and it was not the video card or the monitor. But it is far too coincidental that both your machines are doing the same thing.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
