Strange problem with Fonts
Zizou87
As the title says. I cannot remove a file called tahoma. I guess this is the font that Vista uses?
I recently installed Left 4 Dead and later uninstalled it. There was one folder named fonts that didn't got deleted. It contained fonts like arial, verdana and tahoma. I managed to delete all of them in safe mode except tahoma.
I know that you shouldn't delete fonts that the system is using but there is something wierd because it's not in my "fonts folder" from the controlpanel. And the fonts that I deleted succefully (verdana and arial etc.) is still in that folder, tahoma is also there so that's why I'm guessing that I could delete that the tahoma font in my left 4 dead folder without it causing my system any problems.
Can anyone help me find a solution to this problem? Sry if my english isn't perfect.
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
Have you uninstalled left 4 dead?
If so try ccleaner.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Thanx for the tips. I've treid to use ccleaner and I have full ownership of the file.
It still says "This program is beeing used by another program"
Strange indeed. Isn't there any other way to remove a file.
Hello,
I have same problem after uninstalling this game :huh:. In addition all system fonts ( Tahoma) gone Bold and thats annoying :shock:. And my friend have same problem on WindowsXP..
Thanks
try this link .... "http://fps.garena.com/forum/viewthread.php?tid=461214"
download a fix file , change the extension make it .bat , run as admin
u'll get the original reg settings
cheers !
I have a similar problem -- I discovered a bumnch (50 or so) of new typefaces in my fonts folder - most of them have chinese names. I immediately thought I had been botted and went through all kinds of steps to detect it - no sign of a problem, but the fonts may have been loaded in the past sometime. They are all owned by "Trusted Installer". I can change ownership by going through a painful permission process in the font properties dialog, but after I own them and try to delete them the same message comes up, "This file is being used by another program". How can I get rid of these fonts which are hogging my memory? And how can I get "Trusted Installer" status so I can delete them in bulk?
Thanks.
    Dell Inspiron 530
    Intel Core Duo E6550 2.33GHz
    3GB
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
