fatal system error, PLZ HELP
bvories
Hi, Im new to the forum and am unsure as to where this should be posted, if needs moved please feel free. Am hopeful someone is able to help me. I uploaded the auto updates from Microsoft this morning and when I restarted my system, I get this error message.
STOP: c000021a {Fatal System Error}
The inithial session process or system process terminated unexpectedly with a status of 0x00000000 (0xc0000001 0x0010037c).
The system has been shut down.
My system WILL NOT boot all that happens is this message on a blue screen.
How do I fix it.
Thank you.
Bret
    Acer Aspire 3100
How do I fix it.
Thank you.
Bret
Are you able to boot the system into "Safe Mode" or "Last Known Good Configuration"? (After you turn on your computer, when POST has completed, but BEFORE Windows starts booting, continually press the <F8> key. When the Windows Boot Menu appears, select Safe Mode)
If "Last Known Good Configuration" does not work, then try Safe Mode. If you can get into safe mode, the try removing the offending update. Failing that, use System Restore to revert back to an earlier state before the update was applied.
In either case, once the system boots normally, go back into Windows Update, and this time perform a Custom Installation, then hide the problem update.
If the update happens to be a driver, then you should really go to you computer or device manufacturers website and download an updated driver from them. I've heard too many "horror stories" of Windows Update supplied drivers causing no end of grief. Although I must admidt that in well over a year, I've never had that particular problem...
Directly from Microsoft:
If the error occurs during system startup, restart your computer, and press F8 at the character-based menu that displays the operating system choices. At the resulting Windows Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. If this does not resolve the error, try manually removing the offending software. If the system partition is formatted with file allocation table (FAT), use an MS-DOS startup disk to gain access to the computer's hard disk. If the system partition is formatted with NTFS file system, you might be able to use Safe Mode to rename or delete the faulty software. If the faulty software is used as part of the system startup process in Safe Mode, you need to start the computer using the Recovery Console in order to access the file. If a newly installed piece if hardware is suspected, remove it to see if this resolves the issue.
The above quote comes from : Bug Check 0xC000021A: STATUS_SYSTEM_PROCESS_TERMINATED
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
no i am not able to boot the system in ANY mode, If I try to start normally, i get the BSOD with basically the same message above following memory dump, the only real difference is this series of numbers (0x0001003d0) in place of the last series of numbers in the previous post.
    Acer Aspire 3100
Hello bvories, welcome to Vista forums!
I haven't had an Acer but I believe you can use these instructions to see if a
"MS. System Restore" will help you.
Have a look at this tutorial at the link below.
http://www.vistax64.com/tutorials/76905-system-restore-how.html?ltr=S
Start with the machine off, press the power button, as soon as you do that start tapping the F11 key. That should take you to the "Recovery Center". It may take more than one attempt to get there, if the first attempt fails.
Once there see if a "System Restore" is an option use a restore date before the update.
Keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
I am working with a fresh build of Vista and was getting the exact same error. Did you resolve this and what was the answer?
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
Ok, heres what has happened. I finally was able to get the system to do something other than give me the BSOD by utilizing the F11 key on start.
Once I did that the system automatically went into repair mode and then started normally, when the computer booted I was showing "configuring updates-2 of 3 complete" Once the third update completed the system shut down, restarted (without any problems), and has run perfectly since.
My only conclussion is that somehow it lost power during the update process and something in the process prevented it from booting normally.
Anyway, all seems fine now and I appreciate everyones help.
    Acer Aspire 3100
Hello bvories.
I'm pleased you found a solution, thanks for posting back!
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
