Domsy
I recently had graphics card problems and had to get my 8800GTS replaced. This took several weeks and now I'm running a 8800GT perfectly fine.
However, I've noticed my Power Options seem to be corrupt. Upon going into Power Options in the Control Panel, it says "Your power plan information isn't available."
I cannot understand why this has happened. I haven't touched any settings or anything to do with that. I have tried System Restore to an earlier point (before I got my new graphics card) and it didn't seem to help.
The help on the page says that registry keys may have become corrupt or been deleted. I'm not sure if this is the problem, but if it is how can I fix it? System Restore didn't help.
I would like to avoid doing a Repair with the Windows disc. I'm hoping there's an easier way to fix this problem. There has to be! I've been looking on Google and there is hardly anything on this problem. The very few people who do have it cannot seem to fix it, or used previous registry backups (which hasn't worked for me). There doesn't seem to be any resolutions from Microsoft at all.
I also tried using the "powercfg" commands in the command prompt, but didn't seem to have any luck there either.
I'll really appreciate any assistance! I cannot Hibernate or Sleep at the moment and it's a real inconvenience. I'd really like my Power Options back!
Thank you very much,
Domsy
Edit: Oh, and I've used "sfc /scannow" to check for corrupt files and it came back clean.
Domsy
- Intel Core 2 Quad Q6600
- Asus P5K-Deluxe
- 4GB DDR2 800MHz
- XFX Nvidia Geforce 8800GT 512MB Alpha Dog XXX Edition
- 1280x1024
- A lot
- PSU
- Corsair HX620W
- Case
- Gigabyte 3D Aurora
- Cooling
- Quiet air
- Logitech MX Revolution
- Logitech G15
- Up to 8Mbps
