backup, restore, and system restore problems
I've been facing issues with backup / restore / system restore - Hope fulle someone may help me. I've attached screenshot as help. Kind regards
    Lenovo T61p, 3Gb RAM, 100Gb HDD
    Centrino pro
    3Go
Have you found a solution? This started for me approx 8 days ago, identical results to you
Kotuku
    Intel Core2 Extreme Quad Core
    XFX MB-N790-IUL9 NFORCE 790 U
    4 Gb (2x2) Gskill DD3 1600
    XFX 9800GX2 Black Ed. 1Gb DD3
    2x WD Raptor 150 Gb SATA 10000rpm in Raid0 plus 500 Gb Seagate 7200rpm SATA2
I can't open that SYSTEMRESTORE.doc either, so I have no idea what the problem is. I guess that's why calabrache didn't get any helpful replies.
    home assembled
    Intel Q9450 quad core
    Asus P5Q Pro, Intel P45 chipset
    4GB : 2 x 2GB G.Skill DDR2 800MHz
    Gigabyte 9600GT
    Realtek onboard the mobo
    BenQ 24"
    1920 x 1200
    2 of Samsung HD501LJ SATA2 500GB and a few IDE hard disks on USB for backups
    Corsair TX-650 and APC UPS
    Antec P180
    OCZ Vendetta2
We can't read the attachment -please post a jpeg screenshot - not a .doc file.
Thanks
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
I save the doc file to HD and it opened OK from there. It is just a bunch of screenshots of the error messages and screen prints of some C:/ readouts. Basically same error I guess we are all getting and this attached error message.
I have snapshot Rx installed so that covers me for restore points and for a complete backup, but I would like to get this problem fixed. Note you should turn off the system restore, otherwise each day it trys to make a resotre point and that takes up a bunch of CPU's for 2-3 mins
Frenchy
The message "Insufficient storage available..." suggests you either need more free space available on the C: drive or (more likely) probably the amount of disk space allocated to system restore is too small. This tutorial tells you how to change the setting for "maximum system restore size":
http://www.vistax64.com/tutorials/76227-system-restore-disk-space.html
    home assembled
    Gigabyte 9600GT
    BenQ 24"
    1920 x 1200
    Antec P180
    OCZ Vendetta2
I wish it was that easy! No, I have played around with this and currently have 70 Gb Max size and 0 in use and 0 allocated. This is a bigger problem, as more than one (from the news groups and other forums) has this problem. I have heaps of room on HD. No obvious solution yet. I have a suspicion that a Windows update broke this, the fact that a bunch start reporting the problem.
