Problems with DPI, resolution, etc
Zanderthecat
My Vista is about 10 days old and I've gotten into some problems. I tried changing the dpi to 150%, but it changed to 192% and I cant' get it back down. The 'apply' button is beneath the taskbar and not reachable!
Same with the resolution--I made it less, but it is too fuzzy. However, can't get it back because 'OK' button isn't accessible.
In Word, I've lost the regular 'save as' format and it takes me to some screen that won't work.
Please help and thanks. Z
right click any where on the open desktop. click personalize, then click resolution, change to what ever you want with slider. click apply and OK and thats it.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
I've had a similar issue. My HP Updates window, when it popped up after changing my DPI, the text came up off to the side and I couldn't see the OK and Cancel options.
Anyway, I looked around and I can't find any other way to change the DPI other than that window so what you could do is when you're on the window, just hit Tab and try your best to guess which option you're on and then hit Enter. Seems a little silly but it should work lol
    Nvidia GeForce 8500GT
    750GB
Hey, Dudeman, that worked. I'd already tried all of the right click on personalize and like you found--I couldn't access the OK or Apply. I finally just hit Enter and it changed the DPI--then it was easy to do the resolution.
Is this the place for a Word question? SOmehow, when I go to CntlS, instead of the normal Save format--it takes me to a screen entitled Save As; toolbar says computer>OS>Users>Janet>Documents. Then it prompts a File Name, with Save as Type underneath it. Then, Authors; tags; title; subject;manager;company;categories;comments.
I can save there, but it's a lot of trouble. How do I get back to the regular Save As screen?? Thanks again to all.
Next time you get an issue like this where you can't se the Apply button, try pressing <ALT>+<A>. That is the usual hotkey for Apply...
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Unless it is disabled....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Hi Zanderthecat
That "is" the normal Save As window for Word 2007. You don't need to add anything in all those other fields and it should default as a Word Document (.docx) so all you really need to do is name it and change the directory you want to save it into if you want.
Once you have named and saved a document, the next time you have it opened, the Ctrl+S keystroke will now do a Save instead of Save As, and it does it without closing the doc.
As usual with anything in Word, even the Save As screen can be complicated with all the options it can give you, but us normal folk rarely need all that outside of a Business environment.
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
