You should upgrade or use an
alternative browser .
Power Save mode after Outage
I put this in another forum but I'm pretty sure it was the wrong one so here is my problem.
Last night my power went out. Every time my power fails Vista will only start up in safe mode. If I try to start it normally it just goes right into "Power Save" mode. This has happened a handful of times, however it is usually an easy fix. I would just go into safe mode and run system restore and restore my system to a previous date. This however did not work last night. I can still boot up in safe mode. All of my files are still there. Can anyone help with this?
Hi Ricky,
Check in your BIOS power management options for a setting or option to specify how your computer should startup after a loss of power.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Ill take a look, I will let you know if I find anything. I'm pretty sure I tried this yesterday and it didn't work. I will give it another shot though.
I still cant get this pc running correctly. I tried the Bios thing and changed the setting and that didn't seem to work.
Has this ever happen to anyone else? any more suggestions?
Operating System
Operating System
I cant seem to get any of this to work. I haver decided to just start from scratch.
I'm trying to reinstall vista now. However when I choose my drive to install it does not let me. It says something along the lines of "Cannot find requirements on partition"
I don't have the exact wording. I'm going to try it again now. any help would be great.
the exact wording is "unable to find system volume that meets criteria"
Do I just need to format the drive?
well this sucks. I just formatted the drive and it still wont let me install vista on the partition.
Did I just kill my pc?
I used to have no problems reinstalling a OS with XP. This is pretty frustrating.
Ricky,
Are you booting from the installation DVD to install Vista?
If so, reset your BIOS to the default settings to see if that will help, then try the clean install again.
Operating System
Operating System
yes im booting from the Vista DVD that came with my PC.
I reset all my Bios to defaults.
I'm still getting this message when I try to install Vista on a partition that has over 250 gigs free.
Ricky,
See if deleting all of the partitions, in Drive options (advanced) during the install, to have one large drive again and selecting it will help.
Operating System
Operating System
ok ill go try that now.
thanks for all your help Shawn!
I got it to one partition now. Im still getting the same message when I try to install though.
Be sure to format the new one large drive to.
Operating System
Operating System
I did still a no go. I have no idea whats going on.
Is there a way to make sure this partition is active? I have been reading up a little bit and it seems like this may be the problem.
Ok.
It should set the drive as active during the installation process automatically.
For now, disconnect any other hard drive from the computer. Check in the BIOS to make sure that this hard drive is listed and setup properly as a IDE or SATA drive. If it is a IDE drive, make sure that the jumper pin on the back is set to the Master position.
Operating System
Operating System
I went into my bios and set my hard drive as the first thing to boot up with the DVD drive second. I have gotten one step further doing this. All is going good now. Ill see what happens I guess.
