I just got a new LCD monitor to replace my old CRT monitor.
the problem is the LCD doesn't support the resolution i used to have on the CRT which was 1280x1024
the maximum resolution on the LCD is 1280x768.
well i have XP and vista dual booted and when i put up the new monitor i did everything in XP and totally forgot about doing the same thing for vista
so now my problem is when i try to log into vista i get a "Frequency out of range" because the vista resolution is 1280x1024 but now i have no idea how to fix it...
any ideas?
any ideas?
- Pentium 4 3.0ghz/ Dual Xeon 2.8ghz 8 cores
- Intel D915GUX
- 4gb DDR2 533MHz Memory/4gb DDR2 FB-DIMM
- ATI Radeon x600 Series/ATI Radeon x2600xt
- Dual 19" Gateway FPD1965
- 1280x1024
- 2tb WD Velociraptor 300GB WD 40gb Mac Pro - 500gb, 2x 320gb, 150gb
