what are the difference between Vista ultimate 64 bit and 32 bit ???
elnaka
Can any one answer me please .....when can i use 64 bit ?
I am using a processor intel pentium 4 3.0 ghz
geforce 6200 turbocache
2 giga ram
What is recomended for me to use?
Thanks....
2 giga ram
Thanks....
Hi elnaka,
You can use 64bit anytime as long as your processor supports it, Find out by running CPUID for detailed infomation on your CPU/Motherboard and memory speeds.
dmex
Hey Elnaka,
Your processor is 64bit capable (see extension EM64T in CPUZ), If the rest of your hardware and devices are 64bit capable then you can run it for sure.
dmex
Thanks for your help.....here is a screen shot of the CPU-Z.....supports??
[URL="http://img158.imageshack.us/img158/8611/intelkh5.jpg"][URL="http://img158.imageshack.us/img158/8611/intelkh5.jpg"][URL="http://img158.imageshack.us/img158/8611/intelkh5.jpg"][/URL][/URL]
[/URL]
but i need to know what are the differences?
Is it good for me to use it or not?!
Thanks again
basically the difference is you can use all 8gb of ram, your pc is ready for future generation of software & vista acts a lot smoother.
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Thanks alot......and i got some more useful information ....so that it may help others
A description of the differences between 32-bit versions of Windows Vista and 64-bit versions of Windows Vista
What should u have to use a 64-bit version of Windows Vista:
You must have a computer that has a 64-bit processor. Also, you must have 64-bit device drivers for the devices that are in the computer.
Differences between 32-bit and 64-bit versions of Windows Vista:
Memory accessibility (Can access more than 4 GB).
Memory management (Uses of 64 bit packet instead of 32).
Enhanced security features.
The greatest difference is the ability to access physical memory (RAM) that is above the 4-gigabyte. This physical memory is not addressable by 32-bit versions of Windows Vista. A 64-bit version of Windows Vista supports from 1 GB of RAM to more than 128 GB of RAM.
What to consider when you install a 64-bit version of Windows Vista: • 64-bit device drivers may not be available for one or more devices in the computer.
• Device drivers must be digitally signed.
• 32-bit device drivers are not supported.
• 32-bit programs may not be fully compatible with a 64-bit operating system.
• It may be difficult to locate programs that are written specifically for a 64-bit operating system.
• Not all hardware devices may be compatible with a 64-bit version of Windows Vista.
Different versions of 64-bit Windows Vista: Windows Vista Home Basic -4 GB of RAM
Windows Vista Home Premium -16 GB of RAM
Windows Vista Business -128 GB of RAM or more
Windows Vista Enterprise -128 GB of RAM or more
Windows Vista Ultimate -128 GB of RAM or more
