You should upgrade or use an
alternative browser .
ati catalyst control center problem
hi i have a problem.when i installed ati driver on vista 64bit and restarted it gives this messege "CLI.Implementation problem" i have the newest driver of ati (catalyst 7.7) but i cant solve this problem please help me.
Hi sercan17m,
I installed mine without the Control Center in the custom install option without any problems.
You may also try uninstalling it completely in Program and Features, then try installing it.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
but i want to use catalyst control center for custom settings.
Ok,
You can still use the CCC. Just uninstall it from the Programs and Features in Control Panel to hopefully get rid of the problem, then install the newer 7.7 version with the CCC. Make sure you choose "Install" not "Update" at the begining of the installation. Hopefully this will do it for you.
Operating System
Operating System
I would like to thank a guy named, "Brink."
You posted a solution here.
and it completely solved my problem! I was unable to reply to the post because it was too old, so I'm just thanking you here. :D
You're most welcome Dr. Davenstein.
Operating System
Operating System
