chrislloyd2
Hope somebody can help with this. I have a new Vista Premium 64, it has it's own driver for the above parallel port printer (about 10 years old!), which is installed. If you try to print the job will spool and sometimes the printer will spew out a blank page or two, but usually the printer just makes a noise to start up printing and then the power light just blinks, the job disappears from the print job window in vista - and thats ya lot! Any thoughts/ help appreciated.
Regards,
Chris
Regards,
Chris
